Hi people, can anyone help me out??
Just need to know where you bolt it and what type they are if anyone out there has one?
If anyone would post up a pic that would be greatly appreciated :whistling:
Really need it to tow the bike trailer!
Thanks in advance if anyone can help :)
https://www.sau.com.au/forums/topic/180351-stagea-tow-bar/
i hjave checked the treads and didnt find anything on wa owners wit towballs. i need one now that we sold the misses corrola and no cars have tow ball. anyone fitted a removable tow b as i dont like the look of a towball. think there called rece hitch or sumthin like that
https://www.sau.com.au/forums/topic/180351-stagea-tow-bar/#findComment-3281072
the one I've got (same as ian and a few others) has a removable hitch...mine is also rated at 2000kg, I tow a gtr regularly. I had it shipped from canberra to sydney for fitting so I'm sure you can get the same guys to send one if you can't get one locally. Max at Towbars of Woden - he has a jig made up so he can make new towbars without needing the car in
https://www.sau.com.au/forums/topic/180351-stagea-tow-bar/#findComment-3281787
G`day jerome give the boy`s at autoholesales in beckemham.albert,his son has the white series 2 seentowing trail around.so give him a buzz,
https://www.sau.com.au/forums/topic/180351-stagea-tow-bar/#findComment-3281843
  • 3 months later...
use the search button, this has been covered IN DETAIL before (many of us have heavy tow bars (mine is rate at 2000kgs..))..
Hi there Ian, Can you please post a link to where this is covered, or some info on where you got your towbar from as when i did a search i got this thread..
Thanks
Oz
https://www.sau.com.au/forums/topic/180351-stagea-tow-bar/#findComment-3492096
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
