i wouldn't stress too much, just spray the crap out of it.
I used brake cleaner.
Someone suggested to use carby cleaner, it is more or less the same as brake cleaner but it has stuff to dissolve grease/oil as well. Though someone told me recently _not_ to use it because it leaves a residue.
I'd play it safe and use brake cleaner. It doesn't matter which direction you spray it from.
  • Replies 40
Don't you know it... and I was getting ready for a real battle to work out what it was.
That said, I'm still gonna be cautious for the next few days, and see if I can get it to stall. I had a bit of a shock when I put everything back together and the car started idling from 1000-2000rpm. I thought 'great, now I've really fixed it.' Turned out I hadn't plugged the AFM plug all the way in. Plugged it in and hey presto!
i used a combination of metho and kero and it cleans the oily film off the afm as soon as it comes into contact with it. being a spirit, it also evaporates and doesnt leave a residue
plus, you can buy it cheap at hardware stores :P
was getting over 600km to a tank in my former GTS-T :)
  • 6 months later...
Well i used it anyway, as i figured even if it left a residue then id be able to get it off using carby cleaner anyway. Seemed to make the car a little bit more smoother to drive, but im not sure whether the hesitation i have been getting is gone or not. Made sure i blew out as much of the WD40 as i could with an air gun. Will have to see on whether this has owrked or whether it was my o2 sensor!
Cheers, David
Edited by R32Abuser
Nah not overly...a little tho...What happens is ill be on like maybe cruising throttle position whilst accelerating softly to 60 and in second or or third it all of a sudden cuts out and starts rolling as if its going to stop...2 seconds later...it jerks and fires up again and all is sweet. I must say tho, it does feel even when cruising that the engine is under more load than it should or used to feel like....
AANY ideas? Im leaning towards the the o2 sensor..but anyone had similar troubles with different outcome?
Hi mate. I'd place money on it being the AFM, but not the element/hot wire but the plug/connector. I had the same problem with one of my AFMs. The joins inside the plug go dry, causing the resistance to go sky-high (to infinity), which results in the voltage dropping off to zero. The ECU doesn't know what to do and you end up with the rough running for a few seconds until it jiggles around and you have a voltage across the plug again.
You can test for it with a Consult cable.
You can fix it by either replacing the AFM (but hard to check which one it is without a Consult cable) or by desoldering and resoldering the joins. The job isn't actually that hard, provided you have a desoldering tool. I'll chase the DIY and post it here.
Mark
How'd you do that? Spray bottle with a 50/50 mix of kero and metho?
600km to a tank sounds nice... I managed 8.75L/100km at the pump last time and my AFM hasn't been cleaned in a long time. If I could push it a little further I'd be a very happy man :woot:
  • 3 months later...
Good son of rajab! WD40!? Please don't use WD40. I would personally avoid contact cleaner. Brake cleaner is designed to evapourate completley. Id spray a plate with it, let it dry and eat off of it :happy:
If your AFM's hellah visually dirty, carby / throttle body would be best, as its unbelievably powerful at removing carbon deposits, but i would then use brake cleaner to wash it off. Shake the unit gently so most of it spits out, then place in warm spot (vertically on hot cam cover works well) to dry quickly.
I would still be nervous using metho/kero.
Rem, what ever you use once will work and prolly not hurt, but i cant imagine continual use of some of these options would be healthy... reason not to use oiled foam filters ha. Just my opinion.
my 2 cents
-M
Well id personally use contact cleaner to clean electronics .. Otherwise I would use 100% isopropyl also drys instantly and designed for electronics...
now .. does anyone suggest a reset of the r34 ecu or not?
Just buy electrical contact cleaner, do it right first time. I had a pretty dirty/oily AFM when I first got the car, the electrical contact cleaner got rid of it in a flash, and dries within a few seconds.
I sprayed it all around the inside of the tube too, cause it was also dirty/slightly oily, ran my finger around the inside after spraying, totally clean :)
Fixxxer :)
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
