hey, I knocked a Koala out a month or so again and as a result have been left with a mark on the front spoiler (size of a koala head :) ) I'm wanting to touch it up
I'm planning on replacing with a aftermarket front bar sooner or later so not worth getting a respay just wondered if anyone knows what white the 1995 r33 gts25t's have on them
I went to get a touch up kit at local super cheap auto :bahaha: but there is like 100 diff whites guy at store was no ficking help
anyone know what color white?
I really don't want to go in to a panel beater to find out :D
https://www.sau.com.au/forums/topic/18038-touch-up-paint/
but even at supercheap they probably won't have the correct code for an import... i haven't been able to find any place that has it in a can for AN0 (skyline burgandy).
There have been threads about this b4, but try an autopaints specialist, or Nissan Australia (apparently they stock some for imports).
https://www.sau.com.au/forums/topic/18038-touch-up-paint/#findComment-377447
the code on my white r 33 is QM1
and i matched the code in a book at a
auto shop(SORRY CANT REMEMBER WHICH ONE)
and it was called POLAR WHITE
BRAND is POWER PLUS their code is PJ2142
there was actually two polar white with two different codes
so i just picked the one i thought was the closest
i didn't think there were so many shades of white
i hope this helps
eryc
https://www.sau.com.au/forums/topic/18038-touch-up-paint/#findComment-379181
well white is quite easy cos its white u know! with the wine red, its got a pearl mica in it and the closest is vintage burgundy which is same colour in the sun and ultra bright in the shade. the closest ive found so far in a can is actually cardinal red (metallic) which is a toyota colour
https://www.sau.com.au/forums/topic/18038-touch-up-paint/#findComment-380135
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
