looking to buy some new rims and found that my r33 s2 NON TURBO gts-4 uses 4 stud rims and turbo models use 5 stud..is this correct?
well ive been searching around and not easy to find 4 stud rims that use 235/45/17 tyres and abit frustrated. there r 17'' 4 stud rims but uses 205/40/17 from 4cly cars etc and seem abit small for me and less grip? so wondering does any1 around here have a set of 17'' 4stud rims that may fit 235/40/17 on onto my r33 :( or close 2 it that will sell?
thanks for any help
https://www.sau.com.au/forums/topic/180386-looking-for-4-stud-rims/
I think you'll have a better chance of finding nice/good 4 stud rims on nissansilvia.com because they've got more cars which use 4 studs (S13's, 180sx etc).
And it's pretty hard to find nice 4 stud wheels. Good luck with your search.
the wheel is 17 inches in diametre, is 9 inches wide, and has an offset of +32
if you want the definition of offset, use google... I know what it is, but cant really explain it
Edited by retox
Oh one more thing. Do your research with offsets before purchasing wheels. Usually the lower the offset, the more the wheels would stick out of your guards. I think just learn abit more about wheels in general and you'll understand what offsets you want/need.
thanks, atm im using 235/45/17 tyres and need advice on what size rim is suitable. 17x8? 17x9?
also i am unsure of what my stud pattern is. Since being a nonturbo s2r33 its a 4stud and i THINK i read somewhere its 4x114.3? not sure
some1 correct me lol
Edited by OoskylineoO
Yes, you are correct! Skyline 'PCD' or stud pattern is 4x114.3 or 5x114.3, I'm not sure of the offset values for the 32's or 33's but I assume they would be simlar to the 31, however you'll have to allow for brake caliper clearance and clearance of the strut. They are the main issues when trying to find 4x114.3 rims.
Like the others have said, it is hard to find that style rims. Workout what offset is ideal (for the R31 its +10 to +30 7 to 9" rims)
Depending on what sizes you want, you'll have to work it out. Anything about +35 is going to give you issues clearing the struts.
The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tyre assembly. This in effect brings the tyre further into the tyre well.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset. a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
Like others have said nissansilvia & other silvia or Toyota sites are good, as they share the same stud patterns. if you have a good amount of money to spend you could always look at importing something from japan, as there are some amazing rims at decent prices.
hmmm 4 stud rims arn't that hard to find...i mean you can get 4 stud Nismo LM4's i think thats waht they're called and works meisters...in 17 inches or so the question is are u wiling to pay the price :nyaanyaa: but yeah go on nissan silvia there is some one there selling rims especially 4 studd ones for cheap well reasonable prices :thumbsup: hope that helps
Cheers
Chi
hmmm 4 stud rims arn't that hard to find...i mean you can get 4 stud Nismo LM4's i think thats waht they're called and works meisters...in 17 inches or so the question is are u wiling to pay the price :D but yeah go on nissan silvia there is some one there selling rims especially 4 studd ones for cheap well reasonable prices ;) hope that helps
Cheers
Chi
Yeah, it's not all that difficult to find 4 stud rims. It's just hard finding ones with good offsets and a good/affordable price.
Another thing to consider is possibly converting ur 4 stud to 5 stud. Its a worthwhile investment and will open up a whole lot of possibilities in terms of wheel choices. 4 stud wheels are out there but to find a set with the right offsets and at an affordable price is gonna be pretty hard.
Yeah it cost about $1000 for the parts and I think it was installation as well? for the 5stud and bigger brakes. I think it'll be a good upgrade if you can't find any good rims. Not only do you get 5 studs, but you also get bigger/better brakes.
o oright ill think about that but atm i got another question lol, so 235/45 tyres would fit on both 17x8 and 17x9 rims, since i have a gts-4, if i had 17x8 rims on the front and 17x9 BUT i put 235/45 tyres on ALL the rims would that still affect my ATTESSA????
would 17x7 rims rim seem abit umm..thin?? on an r33 lol
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
