My Engine Rebuild
Hi, it is a slow process but it looks like it going to cost me about $12,000+ for this motor rebuild + extras.
I had a look at the no.1 piston when they got the motor apart and had cracked ring landing. Scored the bore, hopefully machinable to 20 thou, cause from old motor, or maybe over boosting it without tuning. (My bad). Either way it was needing a rebuild in time to come.
I found I had a nismo single spring button clutch in the car, so just going to reco that. - $800+
The type of pistons that I'm going to use are called Arie's/Aeries something like that. (Forged Pistons)
The turbos I'm going to use are called 2830 -5 twins I think. Can anyone tell me anything about them?
And the P.F.C I was thinking about using is called WOLF. Does anyone know of these computers?
Thankyou
WHITEBEAST
Hi,
I had a rebuild on my R32 at Racepace, where are getting it rebuilt? I also used Arias Forged pistons. Arias are a very well respected brand, but more important is your rebuilder is experienced with the piston and not have too much clearance. Ben knows exactly how much is too much and used the tightest setting and I had absolutely no rattle on start up and near zero engine roughness.
I dont know what the 2830's are (are they HKS?) but I know a popular turbo is the HKS GT2530's. I opted for the HKS GT-SS which are slightly smaller, but are a little more responsive. Had 90% peak power buy 4000rpm till redline so it made driving it very easy. Dyno gave 313rwkw, with GT2530 prob would have been around 330+rwkw.
As for ECU, I PFC refers to the A'Pexi Power FC. Its an excellent option cos its plug and tune, whereas other standalones may need new sensors and rarely have a base map so install costs are much more. I was thrilled with mine but it doesnt matter what you use, its who tunes it that matters.
All I can say is you're going through an expensive exercise so dont skimp on costs, get the best parts and builder you can afford. Better to pay more once than pay less twice. I spent about $20k all up (which is on the expensive side) but I never had a problem and the car drove beautifully. Even my friend mentioned it drove smoother than his stock rex.
 Share
