Im cleaning out my oil and would like to know how to remove the oil filter from the RB26 looks really hard, anybody got some ideas or tips they can give me?
mate its a bitch i tried it from under neath on a hoist but i could not get in and the top is a little easier i had to get a mate with small forearms to squese in there to get it off if that helps at all ;)
The rb26 oil filter is just like all those other rb components - ok if you have small to medium sized hands. Unlike a holden or ford fangadore - which haev miles of space, these skylines are tight.
Just make sure that car is cold - its impossible if you've just driven it because you'll keep burning yourself. Keep trying. you'll get more courage, and you'll stick your hand further and further in. Eventually, you'll work out a good way of how to get it.
I've got a GTS-4 and it's a hard job to change the oil filter too. I think the only way of getting it out is to reach in and twist it out. I guess you can always get an oil relocator kit. That's after you get this filter out ;)
I don't think the GTS-4 and GTR boys/girls can change the filter from below because of the front axle and diff? I don't know, I've just changed it from the top and it doesn't look like you can change it from below. ;)
When I changed my oil this is the wrench that I used.
http://www.amazon.com/Worlds-Best-Universa...9752&sr=8-2
The jaws rotate as you turn the ratchet, which tightened down on the filter and squeezes it tightly.
I had to put it on by hand, then get a ratchet down there, I just cracked it to get it loosened then I removed by hand.
Be careful though, because there is both a hose that is kinda in the way and a wire for a sensor down there.
Don't get them caught in the jaws which might tear/pop them.
THAT WOULD SUCK!
Its still a P.T.A. to get to, but its a lot better then trying to dislocate both your arm to reach and your head to see what you need to see to be able to work on it.
Oh and few cold ones do not hurt matters either.
Edited by i4dat
LOL big screw driver and a hammer, drive the screw driver through the oil filter and then you have enough leverage to at least unseat it. Then you can twist it with your hands.
Messy though!!
Messy though!!
That's pretty dangerous. I remember punching a screw driver through my filter and it created really sharp edges on both sides of the filter. Once you put a screw driver through the filter, you need to keep using the screw driver to take the filter off.
Just my experience.
Yer but you have the added bonus that once you have punch a hole through it you just have to change it LOL.
After i broke the seal the filter spanner worked a charm. Then removed Hicas no problem now
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
