ok guys can some one help me with this.
i req new rims as the rims i have, the offset is now to big for the for the front brakes and i have to run a 20mm spacer (+40mm offset rim)
would a +34mm with a 5mm spacer work. the reason why i wont to go to a 5mm spacer as i know it does not throw out the balance like the 20mm and it will also bring the track width in.
if i am corect the perfict offset would be 25mm front and 30mm rear for my car.
i have r33 gtst front brakes (HR31 struts) and std rear brakes.
https://www.sau.com.au/forums/topic/180430-offset-question/
+40 rim with a 20mm spacer = effective offset of +20
+34 rim with a 5mm spacer = effective offset of +29
So the +34mm rim combination has 18mm less track than the +40mm rim combo. Offsets and rim size can be used to determine clearance to the strut and guard, but they can not be used to determine clearance to the caliper, spoke design comes into it for this. The only real way to find out for sure is to bolt it onto the car and see if it clears the caliper.
Also a 5mm slip on spacer is much more likely to throw out the balance than a 20mm bolt on or a 20mm hub centric slip on (like H&R)
https://www.sau.com.au/forums/topic/180430-offset-question/#findComment-3281982
    • If you ask just me you'll get 3 different answers.
    • Do not ever trust ChatGPT with anything math related. They can't do math. They have no idea what it is. With enough data we can fit a decent equation in Excel, or if the available fits in Excel aren't good enough, a Matlab clone.
    • You could check/calibrate that with a thermometer, we have long glass thermometers at work which go from -10 to +150°c, they are pretty cheap too I believe,  as monkey fisted soldiers tend to break them, and getting new ones don't seem to send red flags to the people that hold the purse strings Edit: after a google they apparently cost about $80, but, digital ones seem to be much cheaper at around $40
    • I should have prefaced all of this with "I'd really like to not pull anything out of the car for this"
    • Me, I would happly spend some more coin on better tyres for my street car  Will they work, yes, of course, but why substitute some dry grip/braking distance, and wet weather grip/braking distance on what is really old tech to save some coin on your "precious" street car In the end it might not be you that farks up, it's the thousands of other idiots on the street that you need to worry about  For a street car that gets some "fun time", I have found that a quality tyre that can handle dry, wet, cold (Canberra gets pretty cold) and hot conditions, which may costs a little more, is great insurance  From my experience with them (driving around Goulburn in the winter) the RE003's are pretty poor in cold and/or wet conditions on the street If RS4's didn't hate gripping in the cold I would be running them always on the street,  great in the dry, OK in the wet, but, they do hate the cold, with a passion, I run PS5's year round now, basically, I've found the PS5 to be a great year round street tyre for all conditions, they last well, and are mid range pricing wise TL;DR. Tyre choice is probably like what brand and grade oil you should use, ask 10 people, and get 10 different answers... LOL
