Hello all,
see i've done my searching, and all i've read is that you have to either enclose the pod or put back the stock air box.
my question is however, when you get defected... do you get fined anything? like for example, a pod that is not enclosed gets defected.. will the owner have to pay anyone anything or simply just remove the pod?
and one more thing, what's better, a K&N panel filter or an Apexi lol, and if i get one of these for example, it will be inside my stock air box so if a cop checked under the bonnet they wouldn't notice anything right? and hence i wont get defected right?
sorry for what some may think are dumb questions, but i really need some answers lawl
Thanks
https://www.sau.com.au/forums/topic/180431-what-happens-when/
Mate, i just finished clearing up my problem, I was done recently for a pod with a heat shield as my stock box wont fit over my intercooler piping, was told by the EPA officer he was going to take some shots then the head office will decide what to do as it was not "fully" enclosed.
Month later got the letter in the mail, $200 fine, and inspection needed by approved DECC officer, meaning it had to be done right,Source and refit old intercooler pipes, old box. but the wierd part is the mechanic told me over the phone i was going to have to do a noise test and emmissions test as these were affected by the air filter. My car was engineered for everything else so luckily didnt end up needing to do that( also as i passed the noise test at the pits thanks to EVC) but not sure what the exact process is they follow. Oh Inspection cost $40 at Archers in Granville, spoke to Craig a few times he was a top bloke helped me clear it.
Was told simply enclosing the pod 99% of the time will not pass if it is an EPA formal inspection as they dont pass or fail them, they only take photos and send them to EPA to decide, youre best off replacing the stocker and if you want to keep the pod in, get a custom fitted box for the pod made up like i am after you clear it.
The stock replacement panels for the standard air filter wont be a defect.
Edited by T187
HOLY SHIT! that means i could get fined up to $200!!!!!!!!!!!!!!!!! my gawd!
and you say "The stock replacement panels for the standard air filter wont be a defect." by that do you mean a high flow Apexi panel filter will be all good? plus do you noe which is better... K&N or Apexi.
Thanks!
Yea the panel will be fine, I mean if you want to talk legally any change affecting emissions needs to be engineered, but ive never heard of anybody being done for an upgraded panel filter so dont worry about it, the officer who looked at my car didnt even open up the box just had a quick look. the old "factory option/thats how i bought it" provides a bit of leniancy for those problems if it ever rises.
Sorry not sure which is better, ive got the Apexi panel and power intake pod if that helps ;)
Al
Edited by T187
haha it helps. but soz if im being a noob, but how can u have both? as in u own both? or have them both under the hood at the same time!?
thanks
p.s. by both i mean the power intake pod and the panel filter
Edited by CDA
well actually ive always used the pod as the box wont fit the larger piping, i have the box on now though thats also with the standard piping so thats less flow, and with the boost turned off, and with my HKS ecu unplugged, so i really cant compare them as you can tell theres a huge difference. I only ever tried playing with it a bit with my car all tuned and set once, and within 10 minutes one of the intercooler pipe hoses popped off from the pressure so never again...
But without an effecive heat shield and some sort of CAI theres no point in using a pod.
That would be painful if done by the epa. However when i got done for pod recently i had to get full inspection blue slip, pain in the arse if you have other things that the cops don't pick up on
did you have to pay a fine? coz if you did i reckon theres no point in a pod whatsoever
No fine but the blue slip costs $50.30. Just enclose it, saves worrying about it. But they will always find something else if they want to be a pain
enclose it in a cone shaped enclosure or something more inconspicuous like the stock air box (is that possible?)
and ignuz sez: "I carry the paper around in the car now when cops get a little touchy about it" - that means you can flash that at a cop and they can't defect jack?
I'm sure you could somehow use the stock box, however there are numourous threads around about custom building boxes and there was a group buy a little while ago too. I have one that the old owner of my car had made from some metal just makes it looks all closed off.
Then to make it close to bullet proof get it engineered. Pricey but saves hassle later on
Oh they can if they want to raise some revenue or if I give them attitude.. But 99 times out of 100 they will look at it and say no worries..
I got done for mine by HWP last December
No fines, just had to pay for blueslip, who then demanded I have it engd, so it ended up costing me $350 (And that was a VERY discounted eng cert)
My engineer was in a happy mood, so yeah, cheap prices on eng cert.
A mate got done around 3 months ago in his R33 for a pod filter by HWP, and he copped a $70 fine.
It's up to who ever is issuing the defect notice whether they do or don't fine you, and how much it costs.
just a thought here
wouldn't the big 'ol metal clamped filters that are exposed to the engine bay that people fit on top on carby powered V8s be in the same boat 'flamability' wise as pod filters? hmmm...
Yea plus you cant rely on the cleared EPA notice, as my one clearly states it is not to be produced or shown to police when checking the car after it has been cleared...
simply, its gains vs costs, if you dont need it get rid of it,
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
