ok i've done a search and im quite sure its the abs ecu but can someone please comfirm that the small silver box underneath the hicas ecu in the bood on a serias 2 r33 is the abs ecu, all the wires run down the left side of the car and look olike they go to where the module is but i cant tell cause i bought this car as a shell and there was an electrical fire, and the wires are broken,
Edited by unarmed_skyline
https://www.sau.com.au/forums/topic/180442-unit-under-hicas-ecu-r33/
If you've taken the unit out, try pushing hard on the brakes to see if it locks up. If not then chances are, it's not the abs unit. If it does lock up, reinstall it then brake hard again. See what happens.
i've bought a shell so theres no engine in at the moment unfortunally i cant test that otherwise i would have taken it out and mabye the abs light would light up but the cars half apart atm so i have no power to test it that way either,
thanks for that now i no that thats what it is i should be able to fix the wiring from the unit to the modul as they were all charchole n i couldn't tell exatly where the wires were ment to go to, now ill have a place to start.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
