ok i've done a search and im quite sure its the abs ecu but can someone please comfirm that the small silver box underneath the hicas ecu in the bood on a serias 2 r33 is the abs ecu, all the wires run down the left side of the car and look olike they go to where the module is but i cant tell cause i bought this car as a shell and there was an electrical fire, and the wires are broken,
Edited by unarmed_skyline
https://www.sau.com.au/forums/topic/180442-unit-under-hicas-ecu-r33/
If you've taken the unit out, try pushing hard on the brakes to see if it locks up. If not then chances are, it's not the abs unit. If it does lock up, reinstall it then brake hard again. See what happens.
i've bought a shell so theres no engine in at the moment unfortunally i cant test that otherwise i would have taken it out and mabye the abs light would light up but the cars half apart atm so i have no power to test it that way either,
thanks for that now i no that thats what it is i should be able to fix the wiring from the unit to the modul as they were all charchole n i couldn't tell exatly where the wires were ment to go to, now ill have a place to start.
