Hi!
My rb20 is playing on me. Yesterday I went for a drive.
Car was ok for pretty much whole time, normal driving, could boost etc.
Than I tried to have a speed test with s14 sr20det from.
Turned on my boostcontroller, installed recently. Profecb, tuned to 0.6-0.7 at 1,2,3 gear. Standing, 1,2,3(gave it some revs), go. 1 st gear pulling, 2nd gear car jurks, no boost. I stop immediately. Idle revs not stable, can't drive a car at all, no power under load. Checked all the hoses, seemed fine and in place. Vacuum at idle : -.7 bar, can rev but with some misfire around 2k.
Revs stable at idle.
Than I turned the engine off to let it rest for a bit. Turned on again in 10-15 min, same. Puffed some black smoke when I put in 1st gear and gave it some revs just to move. On the road home I had to built some revs, around 2-3 k and engage the clutch to make it drivable, without doing it it woulnd't built revs with WOT at all, just drop rev and stall.
Came home hooked up consult, no errors - code 55.
Unplugged AFM, 2500 limiter.
Here are some vids shot yesterday and today.
It was a bad idea to get out of the basement park with such problems, but had no choice, had to do it anyway.
Yesterday consult:
http://www.youtube.com/watch?v=Touv0v_TSko
http://www.youtube.com/watch?v=Krp-y-Fc8tA
Today revs under load, driving:
http://www.youtube.com/watch?v=E3Xf99kv0g0
http://www.youtube.com/watch?v=xxD_TbGoR5Q
http://www.youtube.com/watch?v=HGowIKq2JGw
http://www.youtube.com/watch?v=a1vcYxoasiU
http://www.youtube.com/watch?v=Wdu9lumNuuc
My ideas:
Fuel pump. (I have bosch 040, maybe it died ?) shows 2.5 bar at idle. Like it should.
AFM died ?
Timing belt jumped a tooth ?
.Sorry for my english LOL.
Looking forward for some ideas.
Thanks!
Edited by robots
I looked at all the piping and it seems to be all in place. If I understand correctly it won't idle ok and it won't show -.7 vacuum at idle. As no piping - leak, unregistered air is going in.
have u checked ur afm? also wat mods u got on the car? its hard to say when we dont know whats been done to it?
also black smoke could be a turbo? correct me if im wrong, but if you blow the turbo, the car will still run but no boost yeh? shot an exhaust wheel??
Edited by cheez
Mods: stock engine, fmic, stock exhaust, bosch 040 fuel pump.
I checked the intercooler piping and its seems intact. I will go have some fun with my car today. Maybe go get another AFM.
Edited by robots
Ok, I've managed to get my engine boosting and reving again. Problem was with the the pipe from the afm to turbo, air leak. And from intercooler to intake plenum. They all had air leaks once on load. Strange. Than after I get rid of that problem, car became driveable. But doesn't pull as hard as before. Didn't try with the boostcontroller yet. Also turbo now got that flatter sound. And I also get backfire when I change gears. I was like wtf ? Also there was some oil in the turbo>intercooler pipe. Cleaned it.
So now car boosts, has mad turbo flatter sound, doesn't pull as hard and gets some idle rev issue when u back of the throttle or press brakes.
Any ideas ?
Will post vids later.
Edited by robots
Boosting again.
http://www.youtube.com/watch?v=lTYpV9mc1bY
1st gear pull and really loud bang/backfire. It was like gun shot.
Had little fuel in the tank at that moment. So I had something like a fuel cut after that backfire. Damn it :x
http://www.youtube.com/watch?v=jC_ZxgPEe_c
Exhaust note at idle after the backfire bang.
Now I got some drone sound in the downpipe area. Maybe I shot of a turbo exhaust wheel ? :cheers: :?
http://www.youtube.com/watch?v=xyck4sARUe4
And some fun, doing some donuts a week ago.
http://www.youtube.com/watch?v=KFE8Xzy8wBU
What I got now:
1)Engine can rev, make boost.
2)Got mad turbo flatter sound now.
3)Got rid of most air leaks I guess.
4)Car doesn't pull as hard as before. Or I just forgot how it pulled already.
5)And I get backfire bangs nearly every time I change gear. It even backfires on idle, when I rev it and lift off the throttle.
When I was looking for the air leak in intercooler piping, I found some oil build up in turbo>intercooler pipe, wiped it off.
Edited by robots
I had oil all through my piping and exhaust when the seals in my turbo blew, so maybe that has happened.
Not too sure bout the backfiring but when my 32 was still N/A i had alot off backfires or 'pops' as i changed gear and some times when i changed down
The turbo flutter could be from a BOV that isnt opening and pushing out the air back through the turbo (oil in the piping might have gotten into the BOV and is making it harder for it to open). also if there is oil leaking through the inlet side and into the motor that may aslo be holding back some power, and not letting it feel like it is going as hard
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
