1994 Nissan Skyline 5 Speed
127000 klms
127000 klms
Rego till Feb 08
Only been in Australia Since 2002
Car is in immaculate condition not 1 scratch or dent
Car was resprayed a year ago
Never been in any accidents
Always been serviced
Amazing Car to drive and awesome Handling
Series 2 bonnet and headlights
GTR front Bar
Car also has tinted windows
Genuine Skyline floor mats
Sony CD player
Also comes with skyline Car manual
INTERIOR IN THIS CAR IS IMMACULATE WITH NO RIPS OR FADES
19inch Gold chrome wheels
JIC upper ball mount hight adjustable suspension
Car has coil overs
Genuine HYBRID front mount intercooler with polished piping
Full exhaust system & Blow off Valve
Pod Filter
Genuine Apexi Turbo Timer
Lsd Diff
Car has never been boosted... Running stock boost
Car located In Sydney
price is $12900 Neg
Might also be interested in trade/swap for something of interest
All serious offers Considered
Any questions please ask
https://www.sau.com.au/forums/topic/180485-r33-gtst-94-manual/
127000 klms
127000 klms
Rego till Feb 08
GTR front Bar
Sony CD player
Car has coil overs
Pod Filter
Lsd Diff
price is $12900 Neg
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
