Hi All...
Check out my new skyline imported from Japan.
Let me now whats our opinium is about the car, Fine or not fine, CAn i imrove anything Etc, And the best of all i am doing comersialls on the car for the best Forums on the planet....:burnout: :burnout:
Cheers and best regards from Sweden,
Klaus.
https://www.sau.com.au/forums/topic/18051-check-out-this-fine-skyline/
  • Replies 43
Klaus, you cant do much more to improve the look of that car!!!
It's silver and it's an R32 GTR (the best combination!)
You're a lucky man!!
Maybe try and source some Nismo side skirts for it, to make it look a little lower - but apart from that looks wise she's the goods!!
All this is for the new street race movie here in sweden 2fast 2fuerios (Spelling?) And then was it 10 other cars ho had an place in the building their the cinema was held...
Good comersialls was it for you dudes downunder and for the new dude ho owns the super evo here in sweden, jrm-racing.com as a new sponnsor for the car., Please visit him on the web, Cool dude and weary nice to talk to...
Cheers Klaus
Originally posted by sven laptop
That's a fabulous looking car.
Don't change anything - it looks great as it is.
How do you go in Sweden with a right-hand-drive car?
Thanx its fun to here... =)
Its no problem @ all, Well after a hole summer in my old R33 GTS25T so now its no problem @ all...
Only when i should drive the MB vinter car then it is some difficullty...:bahaha: :bahaha:
Did you now the spelling of yours nick is swedisch style (Spelling)??
Regards Klaus
I had in mind to power her up and begin to work on her when i dude from "Estonia" called me and laid a good bid on her,
So i sold the car and now it was not difficullt to pic this new GTR out....
And the best where, He dident whant to have the aftermarket stuff to the car so i kept it...
Cheers K
dun tell me u got one of the the 500 LM editiron R32 made in 95?
Still very nice car, and as they say down here "fully sick" (there's a term to impress your swedish car buddies with)
Do you have to convert it to Left Side Drive or does swedish law allow u to drive Right Side Drive cars?
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
