Hi.
Have a question about me RB25DET s1 engine that im building.
My tourque wrench is one from work, our test department uses it. Its calibrated 2 times a year, and uses a dial gauge built in it. Goes from 0 - 80Nm.
Just tourqed down the main cradle, but now my crank sort of "binds".
When the crank just has been turned around, it will spin free, and only require ~2 N to be turned. (You cant really measure it as it really doesnt move on the dial.) Easy to turn by hand.
When the crank hasnt been turned for a minutte or so it "binds". Will need around ~5 N to get it to spin free again. (On the dial gauge you can only see it move, and then drops back to nothing as the crank begins to turn / frees it self from the "bind")
Is this just oil friction I have to overcome just when turned? or?? Could this be a problem?
Best Regards
Ronni
https://www.sau.com.au/forums/topic/180559-is-this-okay/
The applied force just need to be a little higher to get it to turn over when it has been standing still for a little minutte or so.
After it has begun to turn the applied force to turn it is close to nothing. It turn freely the hole way round. There are no spots were it feels more or less freely to turn.
https://www.sau.com.au/forums/topic/180559-is-this-okay/#findComment-3283101
Have measured both crank and cradle, ordered correct bearings, got the ordered bearings. Mounted with clean surfaces (back side of bearing) and used plenty of motor oil to lubricate.
When it is turning it feels free and top nice. My only concern is what it is that is "holding" it when it hasnt rotated for a minutte or so. What i need to overcome for it to turn.. Could it just be oil friction? Because when using the tourque dial gauge the applied force to get it turning (when i have to overcome what is holding it) is only just the needle moving, only just moving, not even up on the dial...
But when it has just been turned, and then turned again there is nothing holding it. The needle doesnt move to turn it.
Tomorrow i will try with a different tourqe dial gauge. goes from 0 - 8N. Should be apple to see more accuratly.
https://www.sau.com.au/forums/topic/180559-is-this-okay/#findComment-3283150
On older engines, it was perfectly fine to use oil, i cannot comment on whether grease would have been better or worse. But I thought your not ment to use grease on ur main cap bearings.
What I can say, (which sounds like your describing), is that when the crank is stopped, its harder to get moving, then once its free its fine. then when u stop, it sort of sticks.
On the last rebuild on my v8. The crank did the same thing. and it was perfectly fine. If your really worried about it, borrow another torque wrench, and retorque it. and see if its the same.
since their is no oil pressure, the bearing oil hole and groove, can only pickup oil from spinning. when you sit still, the oil is pushed back off the bearing into the groove, you have to then spin it to pick up the oil into the hole and groove again.
Thing is, you must still be able to move it buy hand, at the correct torque. if its harder than that. its possibly too tight.
but i would rather a professional post here. as Im a novice. good luck.
Edited by silverbulletR33
https://www.sau.com.au/forums/topic/180559-is-this-okay/#findComment-3283710
    • I'll measure it up at the lowest point later and post it up Currently painting, with the oven all warmed up to 93°c
    • How much clearance is under the car? We have speed humps being added everywhere around me. Faster than they fix the potholes, thats for sure.
    • After some googling of various websites IRT the best ride height for correct geometry I ended up going,  hub to guard, 330mm in the rear and 345 at the front, these heights came from Flyin' Miata in the states as what they recommend (13" rear, 13.5" front) The rear needed to only come up 5mm, but the front came up 15mm Overall it is around a 25mm drop from OEM ride height, doesn't look all 4x4, and hopefully should be enough height to clear those pesky speed humps I have lost around 0.5° camber on the front, and around 0.2° in the rear, I have no idea about what it did to toe settings so I'll look at a new alignment next week to get it set up how I want, zero rear and a little in at the front I've also stripped the new intake and am currently cleaning and preparing the alloy for some paint, I've headed into work to do it as I can use the ovens in the soils lab to cure the wrinkle paint at 90°c Jackie has banned me from using the oven at home for stuff like this....🤣
    • At my age, 59, I'm in bed by 20:30 nowadays 😴 I'm pretty much a solar powered device, powering up at first light, and powering down when the sun goes down 🤣 Oh to be young again.....
