Thanks for all the replys.
If it is clearance issues why does it change then? Its ONLY when it has been sitting still for a little minutte, it "binds".
Have measured accuratly today with a torque dial gauge. (built in dial gauge), range 0-8N. Its calibrated 2 times a year.
To break the "bind" it need ~6 N.
To rotate it need ~2N, after the "bind" has been broken.
If I start rotate just after stop, I still need ~2N.
If I wait 15 sec, it need ~6N to begin rotation again. (If I wait 5 min. it still is 6N to begin rotation)
There is NO spots were it need more or less N to keep rotation.
Have talked to a engine builder here in Denmark. He says when the crank rotates it draws oil on to the surfaces, 2N friction, when it sits still the oil runs back in the grooves, and crank makes contact with bearing, that is what I need to overcome?
The block is upside down, and havnt tryed doing this when block isnt upside down. Could this have any influance?
Tomorrow I should check for endfloat, and run out on number 4 bearing? What more should I check?
The crankshaft runs on a hydrodynamic wedge of oil which can be squeezed out when the crank sits for a bit and the crank sits against the bearing. Once you turn the crank you pull oil between the crank and the bearing and the crank floats on it. I'd still check the end float, most bearings are made at the maximum thrust flange width which can reduce the thrust clearance anyway. It's quite common to have to sand the thrust face of the bearings to provide the proper end float.
Cheers,
Greg.
Endfloat is: 0.08mm
Run out, measured on number 4 main bearing, is 0.015mm. This is total what the dial show. Souldnt this be cut in half to get correct run out number?
Edited by nissan200sx.dk
    • I'll measure it up at the lowest point later and post it up Currently painting, with the oven all warmed up to 93°c
    • How much clearance is under the car? We have speed humps being added everywhere around me. Faster than they fix the potholes, thats for sure.
    • After some googling of various websites IRT the best ride height for correct geometry I ended up going,  hub to guard, 330mm in the rear and 345 at the front, these heights came from Flyin' Miata in the states as what they recommend (13" rear, 13.5" front) The rear needed to only come up 5mm, but the front came up 15mm Overall it is around a 25mm drop from OEM ride height, doesn't look all 4x4, and hopefully should be enough height to clear those pesky speed humps I have lost around 0.5° camber on the front, and around 0.2° in the rear, I have no idea about what it did to toe settings so I'll look at a new alignment next week to get it set up how I want, zero rear and a little in at the front I've also stripped the new intake and am currently cleaning and preparing the alloy for some paint, I've headed into work to do it as I can use the ovens in the soils lab to cure the wrinkle paint at 90°c Jackie has banned me from using the oven at home for stuff like this....🤣
    • At my age, 59, I'm in bed by 20:30 nowadays 😴 I'm pretty much a solar powered device, powering up at first light, and powering down when the sun goes down 🤣 Oh to be young again.....
