Sliding Performance
sorry bud, but if i a timeframe for delivery/return of emails etc was given, then any customer has the right for them date's to be kept to. Otherwise it's just very poor business.
  • Replies 79
As explained in the PM Simon
If you could send back the clutch and flywheel for Exedy to take a look at they would have gladly provided a report and warranted the item if it did not fail due to improper installation.
We have never had a clutch returned or had one fail out of hundreds sent out.
Jase
Jason
No reply on my outstanding refund yet despite PMs and emails - please address this.
Gav
x2 still waiting for a call from aaron Re turbo, its been 3 weeks now...
An email was sent around 3 weeks ago mate.
Jason
Gav
Hi Gav
Have just been able to speak with Aaron about something we can sort out for you.
I will get back to you asap.
jason have sent pm regarding garrett's
Pm sent Matt :pwned:
I went down and picked up a N1 block from Jason on the weekend.
Extremely helpful and insightful.
I had a set of Garrett turbo's on order and know the situation which i were happy to wait for and from what i can see everything else was running smothly apart from that.
I reckon the people that actually have something they are waiting for should take a f*cking chill pill.
Fair enough its a bit of money for a part but when someone is as f**ked up as Aaron i think most people should be grateful there is even any contact and the business did not just dissapear.
From the looks of the stock pile of parts and shit they have i dont think they could go anywhere theres too much shit lol
I remember buying through Aaron when it was a 1 man band and now there are 3 of them working like a full time staff.
Those that are waiting like a week over due for parts take a seat and wait for them.
Anything that comes out of Japan can be delayed for whatever reason and seriously for some of the prices available waiting another week isnt that bad considering the savings.
P.S. why are emo's so emo?
Hi Guys
All orders that are outstanding have been accounted for now we believe and the best solution will be refunds which have always been available.
If you are included one of the very few waiting on Garrett turbo's (which are the only items outstanding) please see this thread and if you have been missed please let us know.
We are back on top of all orders current and behind with just the 3 we think remaining.
http://www.skylinesaustralia.com/forums/in...howtopic=183006
Thanks, Jason
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
