Sliding Performance
I've always just put that plug in dry (ie no sealant), it is a tapered thread so do it up "fairly" tight but not VFT and it should be fine
I think that will requires @jamesnorman93 to check their link, or alternatively someone else with time to run the PDF through an OCR tool
Are you suggesting that the expert fabricator's work is not as good as Sinco's? Oh, eeby deeby for glup shitto! Eeby deeby for glup shitto for one thousand years!
Doing some research, these thread sealers (including loctite 592) take about 72 hours to cure. Suprised it's that long.
@soviet_merlin note how this is a twin scroll manifold and the "fabricator" has tried to make it a merge however I'm not sure he/she/it did very well at school and understand how gas/fluids flow. And why re-invent the wheel? manifolds like these exist, and the merge is great, not to mention the pulses are split all the way to the wastegate's fire ring:
