I got this message on my screen this morning when i started it up.
The message diplayed "PITT" with a spanner and all this japanese writting.
Does anyone know what this is?? I know all the cars these days are programmed so when the next oil change is required it is displayed on the screen, would it be this?
https://www.sau.com.au/forums/topic/180599-pitt/
Thanks mate,
You know how there is 4 different settings.
What does each one do?? Does anyone know the sequence from top to bottom of screen?
Cheers
Get a chinese friend help you out, they can understand 60% of writeen japanese.
I will check my one after work and posted it here.
https://www.sau.com.au/forums/topic/180599-pitt/#findComment-3285940
    • Hey mate, thread dredging hahah To answer you directly, yes I had my itbs oversized and custom butterflies etc made by EFI Hardware in Sydney back around 2017-2018 if memory serves. My setup had a vast amount of other changes too though, so no direct comparisons unfortunately. i went from oem itbs, HPI manifold and internal gate hks 2835 pro S; to 49mm itbs, cnc port matched Nismo plenum, RB25 Neo lower runner adapter hand port matched, r31house v2 Takoashi MAX equal length twin scroll manifold with twin 38mm tial gates and a FP HTA3076 with 1.01ar twin scroll real hosing. feom power Fc to a link fury wired by 12volt, r32 gtr fuel tank conversion with frenchys twin 460 / surge tabk fuel hanger combo kit, 1659cc injectors, full 4 inch turbo back stainless exhaust, Z34 6 speed, Tomei 2way with 4.3 final drive and a ton of other shit. ive posted elsewhere here with complete run down, but here's a graph from its initial tune with no boost control on, 20psi gate springs only and e85.   7542AE72-DA92-4E0B-8660-B0940FEA7F24.mov
    • On sale mate, $55. Sorted. https://www.supercheapauto.com.au/p/toolpro-toolpro-torque-wrench-1-2-drive/565734.html?utm_content=paidsearch-pmax&gad_source=1&gclid=Cj0KCQjwytS-BhCKARIsAMGJyzqYEnwWmhWf6gxTST_Nz06Gd2VePgyvL7lh6PWrQtbjXTsI6TqSCLEaAuaCEALw_wcB&gclsrc=aw.ds
    • Slap it and say it ain't going no where, you'll be fine.
    • So the whole rb25de neo setup was a tiptronic setup and i swapped everything over to my rb20de neo setup and yes even the cluster of the rb25 was swapped over.
    • and I thought size mattered 😝 At this point I may either pray to the Afterpay gods and get a torque wrench or attach a water bucket to the breaker bar. I appreciate the help though 🙏🏾
