Hi there,
Sorry to rehash an old thread, but can anybody tell me what the Nissan part number is for the in-cabin air con filter for a 2001 V35 250 GT sedan is?
From my research, I think it is N*B727A79925 Filter-Pollen with the OEM number being 999M1-VS251. If you can confirm this, it will be great.
I need to change my filter as the previous owner smoked with the windows up and its probably all clogged up with ash.
Thanks.
Thanks.
Will explore that option.
In the meantime, will the Ryco RCA113 fllter work? Seems like a cheaper option.
http://www.eziautoparts.com.au/ryco-cabin-air-filter-rca113p.html
Thanks
You can get the IN-CABIN MICRO AIR CONDITIONING FILTER - CARBON CHARGED from here.
http://cgi.ebay.com/...sQ5fAccessories
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
