ive heard of a limited run (like 150 or so supposedely RARE AS!) of the r32 gtst or i think they also called it the gtsm about the same time the r32 gtr v spec 2 was released...
i think it came with the same body as the gtr (as in it had pumped guards)
now i always thought the mspec range was just cosmetic differences....
but they say this particular model came with a mspec2 2 rb20det engine... it had higher compression and a different turbo?
they say the engine is distinguishable by not having rb20 printed on the engine cover...
u know how the rb series have rb20, rb25 etc on the front of the engine, well this one is just blank...
i think it also came with bigger brakes..
can anyone confirm this???
ive searched everywhere and cant find much at all....
thanks..
https://www.sau.com.au/forums/topic/180619-r32-engine-spec/
When the R32 V-Spec II came out in 1994 there were no R32 GTS-t's only R33 GTS, GTS-25 and so on.
Series 2 R32 GTS-t and GTS-4 did come with a RB20DET that no longer had RB20 on the cam cover, also the coil packs were different, other then that the engine is nearly identical to Series 1.
All non GTR R32's were discontinued after 1993 when the R33 chassis replaced it.
The only M-Spec I know of is the R34 GTR named for the LeMans cars.
https://www.sau.com.au/forums/topic/180619-r32-engine-spec/#findComment-3287125
There is a series 1 and 2 in r32 gts-t.
There is also a thing called a Type-M.
So you are referring to a series 2 Type-M. The engine is pretty much exactly the same (if not identical)
The biggest difference between Type-M and non-Type-M is that they have the bigger 4 piston brakes, leather gear know, gear boot and steering wheel.
All of the "other" Type-M things (sunroof, bodykit, upgrade interior, front lip) are options available on both Type-M and non-Type-M skylines.
The biggest difference between series 1 and series 2 is that series 1 has blue dials and series 2 has grey dials.
https://www.sau.com.au/forums/topic/180619-r32-engine-spec/#findComment-3294609
All Series II GTS-t's are type-M, All GTS-4's series I and II are type-M. All of them have the bigger brakes, alloy wheels.
I can't recall which ones have which, but series I and series II coils differ in the fact that the contact point is a spring on one and a solid piece on the other.
https://www.sau.com.au/forums/topic/180619-r32-engine-spec/#findComment-3302296
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
