Hey guys, I have most of the parts together and ready for my engine although I need to know what spec cams I should be running for best spool time + peak power.
My setup is going into a VL street/strip car, mid nines is the goal.
Currently I've got rb26 head (would I get away with a minor port job or should i go big with this?)
1000hp plain bearing GARRETT GT42 with .91 rear
1000cc sard injectors
bosch 044 pump
adjustable cam gears
etm exhaust manifold, 4" dump pipe etc
GTR-LINK ecu (will be changed for a motec or autronic but I just want to get the car running now)
RB30 bottom end with CP forgies, spool rods etc.
Gearbox is a jatco 4spd with all the fruit, rated to hold 550rwkw. full manual reverse pattern valve body, 4000 tce stall, transbrake etc.
any help with this would be appreciated as I'm pretty stuck on which cams to use at the moment.
I'm aiming for around 500rwhp on pump fuel with under 25psi, does this sound achievable with the above mentioned setup?
cheers
https://www.sau.com.au/forums/topic/180654-what-cams-to-use-with-my-setup/
If your aiming for 500rwhp, i would recommend downsizing a lot of your components, as they will be causing a lot more lag than is necessary for that power, with 272deg 10.2mm cams and a good port job you should see close to 700rwhp with 25psi. Im basing these power figures on a manual though, not allowing for the loss of power through the convertor.
Edited by Adriano
Theres no way he'll get anywhere near 700rwhp on 25psi! 500rwhp yes. Are you eventually aiming for high 8's or low 9's as thats too big a turbo for what you need. Id sell it and get a t04z if ur not aiming for lower times down the track. I think ur gearbox will limit you to mid 9's anyway so the bigger turbo would be a waste. For cams id suggest 264's with around 10mm lift. Theyd give you a nice compromise
My new motor should make 450rwkw @ 1.6 bar with a smaller turbo, to run a 9 you will need a turbo that big, but will need more than 500rwhp. There have been plentyof vl turbos running 9's with jatco 4spds
Edited by Adriano
You dont need a turbo that big to run a 9! One vl has run 9.8 with a gt35 with a 66mm compressor and one recently ran 9.3 with a to4z so you dont need a gt42. And which vls and how many have ran a 9 with 4 speed jatcos???
no vls have run a 9 on a 4spd jatco, only the 3speeds. im aiming to break my brothers record of 10.1 @ 133 with the 4spd.
im using the gt42 because once ive run the 9 i want then im going to throw in a glide, 9" and some tubs and get serious but for now i just want something that i can cruise on the street and have a bit of fun with.
Im aiming for 500rwhp on pump fuel for the street, hoping for somewhere around 650+ race tune and c16.
ur using a GT42 and u lot r only expecting 650hp on race fuel? :D
that thing should make very close to 900hp with the works
EDIT-
With a turbo that big, ur power band is gonna be up in the high rev range, so a 272 or possibly even a 280 would be the go (whats it revving to?) with about 10.5mm lift
im not sure what rpms to expect with the 30 bottom end, maybe 8500? not sure about 900hp, boostn's setup is alot more serious than mine and its making 915 with a much bigger turbo. ill be happy with 650.
Yeah they can be off the shelf if you want. Just look up nengun or greenline and take ur pick. Im building a 26/30 aiming for low 9's. I got my cams off lukevl in brisbane. They are custom ones i think. They are something like 268 and 272 with 10.5mm lift. Id get them off him if i was you. Kyle sjould be able to help you out with choosing the rigt cams. He knows his stuff!
Yeah into a vl. Was supposed to already be going but somehow changed from a 25/30 with a gt35 and trimatic to a 26/30 with a mr turbo t72 and glide. You know how it goes - well if im doing this, i may aswell get this, oh bugger it ill go all out! Its taking a lot longer and costing a hell of a lot more $$$ than first thought.
exactly mate im the same lol.
mine went from an rb30 with a gt35 (had it running for 1 week) then pulled it apart to go 26/30 with a gt42 lol. keep me posted on how yours goes
my workshop told me HKS step 2 cams (264deg, 10mm lift) are good enough for what i want..
thing is i "only" got a gt35/40... so yeah. but im pretty sure the motor wouldnt have any problems hitting 500-600rwhp, but the gearbox wont like it.
as for porting, i didnt get any done as the 26head flows more than enough, well for what i require anyways :rofl:
Edited by gnki'vlct
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
