With regards to the idler..
When I built my motor up Nissan wanted something silly for the idler, instead I opted for 2 tensioners.
The nissan RB tensioners are locking tensioners so once locked it acts the same as an idler.
RB30 tensioners from holden also do the trick, they were cheaper than nissan, if I remember correctly around $80 each.
  • 5 months later...
  • 3 months later...
Wrong, Only gts-t Type M has the 4 piston caliper like the z32.
Regular gts-t like mine, have the s13 200sx brake.
i believe that is true from the factory but nearly every single r32 gtst i know has the z32 brakes...
they cant all be type-m! :D
also i've been using these oil capacitys with no problem!?
engine: 4L
gearbox: 2L
diff: 1L
cant remember where i got these from but they all sit on full with these amounts in them!
  • 4 weeks later...
i put 5L in my hcr32 and it sits right on full. ive read in a lot of places that 4.6L is correct fill when dropping oil and changing oil filter.
also does anyone have detonation/knock sensor part number. for the back one
they cant all be type-m! :)
engine: 4L
gearbox: 2L
diff: 1L
Well you're doing something wrong
The actual amounts are around:
Engine: 4.6-4.8L
Gearbox: 2.2-2.5L
Diff: 1.5L
  • 11 months later...
  • 1 year later...
sorry to bump this cos its old as but i found this yesterday
R32 Gts-t
4PK0860 Belt Alt
4PK0950 Belt P/S
4PK0925 Belt A/C
94988 Belt Cam (PTFE)
KTBA173 Kit Cam
DT19E Thermostat
DTG18 Gasket (Paper Type)
DTG45 Gasket (Rubber Type)
R32 GTR
4PK0880 Belt Alt
4PK0950 Belt P/S
4PK0925 Belt A/C
KTBA173 Kit Cam
DT19E Thermostat
Does anyone have the part number for a gtst o2 sensor (the ford one will do)
  • 1 month later...
R32 Gts-t
4PK0860 Belt Alt
4PK0950 Belt P/S
4PK0925 Belt A/C
KTBA173 Kit Cam
DT19E Thermostat
R32 GTR
4PK0880 Belt Alt
4PK0950 Belt P/S
4PK0925 Belt A/C
KTBA173 Kit Cam
DT19E Thermostat
HCR32 o2 sensor part number : 2269073L11
got this when i rang nissan and ordered one for my gtst
they didnt have any instock so had to order from japan
which is about 10 work days.
cost me $184
  • 3 weeks later...
cost me $184
thanks but i think i'll go with one from here
http://www.kudosmotorsports.com/catalog/ng...25det-p-42.html
seems a lot more reasonable
  • 8 months later...
  • 1 year later...
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
