Hey Guys
i have been on the forums for a little while so thought i would post up my toy
i bought this car a little while ago from japan it was very rough when i got it but have been slowly fixing it up just need to get a paint job and it will look good
the car when it arrived had
coilovers, FMIC, twin plate clutch, blown rb20 turbo, recaro drivers seat
since then i have changed/added
Handling
new HSD coilovers
strut braces
front adjustable bushes
solid rear cradle bushes
17*8 and 17*9 light weight wheels
Engine
rb25 turbo
a new FMIC and piping
pod fliter
emanage
profec e01 boost controller
Koyo 32mm twin core radiator
HKS SSQV
Interior
Added water temp, oil temp, oil pressure and 02 guages
Brakes
r33 calipers
slotted rotors front and rear
lucas pads all round
Edited by Green_s13
https://www.sau.com.au/forums/topic/180663-my-32-4-door/
yeah that are the standard two door pods but they dont look too bad on the car. yup i'm in QLD.
thanks for the kind words, as i said it needs a paint job badly, but a this stage it is mainly a track car so i'm not in a hurry to get it done
https://www.sau.com.au/forums/topic/180663-my-32-4-door/#findComment-3286145
  • 3 weeks later...
well with any luck over my time off i should have made up my flat undertray for the front bar sorted my emanage issues, (a small wiring mishap blew a diode on the board) fixed up my fuel pump and be ready for the track again in november :dry:
https://www.sau.com.au/forums/topic/180663-my-32-4-door/#findComment-3385508
  • 5 months later...
  • 5 months later...
been a while since i have posted here
but quick update i have had the car off the road for a while, i have put an rb25 in it, just need to sort out a few minor bugs like dead battery and it should be good to hit the track again
https://www.sau.com.au/forums/topic/180663-my-32-4-door/#findComment-4095134
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
