Heya guys,
I picked up my new pride and joy on saturday and im loving it so far, alltho my mate took me for another run in his HR31 with RB20 red top and it is a SHIT LOAD quicker than mine and i cant work out why.
here are my specs
RB20 silvertop ECCS
Rb25 T3 turbo on 14psi
HKS cooler (600x300 ish with was looks to be 2.5" piping.
2.5" downpipe off turbo into a 3" system with two mid mufflers and a rear muffler (5zigen system) (no cat)
standard wastegate and factory bov
turbosmart controller (it is mounted on teh firewall, should it be that far away from teh turbo and the actuator?)
SAFC2 (not sure on how it has been tuned, wether on dyno or in driveway by previous owned)
normal GTST box and LSD diff with coilies and a massive pressure clutch, really bites :P
my mates mods
HR31 redtop RB20
Rb25 T3 turbo on 1 bar
600x300 cooler (unsure of brand)
3" system straight to a rear muffler with Apexi exhaust valve
HKS BOV and some electronic valve control thingo
bee*r
apexi Neo AFC (tuned for about 250hp aparently)
5 speed manual and lsd
we are both running exactly the same width tyres.
(its [THN] s old car (tuyen)
basically his scares the shite out of me, really gets up and boogies and it just pulls harder every gear however mine feels like it has 40hp less or more and splutters around 5K and is i feel it is slower than my 4agze running 13psi.
seeing we both run very similar gear i would expect mine should be a bit faster due to it being a Silvertop, but nooo
could i have a shitty tune on the afc? i just dont get it :thumbsup: i want mine to be as fast.
Edited by YEHBOI
https://www.sau.com.au/forums/topic/180666-my-rb20-st-vs-mates-redtop/
thats why i thort i may have a shitty tune :S i used BP ultimate too.
im not overly sure but with me on my own it isnt even as fast, with both of us in his car which is an extra 80kgs his is still faster. both of them are kept pretty well factory sort of weight. (he doesnt have weight reduction or anything like that)
Edited by YEHBOI
Other than the obvious misfire you have, i'd suggest you have a more restrictive exhaust, and your mates car has a bit of tuning where yours doesn't. Then theres the fairly general term of "T3 turbo". Seriously it could be anything with a t3 flange on it.
  • 3 weeks later...
Obviously there could be many things as to why your car is not as fast. But it comes across as if you assume the silvertop "should" be faster.
The silver came out when all the emissions crap was going on etc. It had a BOV where the red didnt have to. Dont quote me but I think the eccs redtops were also cammed differently i.e more aggresively.
The redtop could of been freshend up in its lifetime where your silver could be on its last legs etc etc etc.
The ex gibson GTSR's run redtops and go just fine lol.
I thought the limit for the 33 turbo was 14.5 pounds??
any idea what a set of coils will be? i have a feeling im not going to get much change out of 2K for a set of brand new ones
Since you are running it on an rb20 you should be able to run 16-18 pounds safely, on the RB25 it's limit is around 1bar, depending on the wheel specs, as long as you have the ceramic and not the nylon wheel, you'll be fine
coils are quite expensive, you might only have one or two bad ones, you can get second handers quite cheap, or go for a wasted spark setup using VL coils and I used VN leads, works fine :( total cost was $140-160, or you could go splitfire for round $500
As for the spluttering, I think it does sound like an incorrect tune on the SAFC
You should:
Crank the boost
Get it tuned
Replace any coils if need be
Don't tell your mate :P
Also if you are running the standard dumppipe you might be restricting the flow, you could always opt for a 3"incher to the cat or a 2.5" with a seperate wastegate elbow which joins up somewhere down the front pipe
What sort of cat are you running? i've you've only got a catback exhaust with standard cat, you won't be gaining the full potential of your exhaust, I suggest if it's all stock, replace it with a higher flowing cat, or if it's legal in your state - rip it out :thumbsup: I've done that to all my cars here in NZ
sorry champ there is a fair bit wrong with this statement, just thought i would clear a few things up...
1. On an RB25 with RB25 turbo you can run 12psi or on an RB20 with an Rb25 turbo you can run 14psi. no higher
2. In regards to the wheels. All RBXX turbos have ceramic turbine wheels. the difference is in the compressor wheel. RB20, series 1 RB25 run alloy iconnel wheels. series 2 RB25 turbos and Neos run nylon compressor wheels. there turbos are limited to around 12psi because the hugher shaft speed required for 14psi is enough to start delamination.
so the clear things up run an absolute max of 14psi. 12 would be safer.
cheers!
id say the spluttering would be coils, get a set of split fires as already suggested, get a 3" dump and you have way to many mufflers in your exhaust. id get a good high flow cat and get the 2 mid mufflers taken out. or forget the cat and still get the two mid mufflers removed.
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
