Is Pauly33GTS-t Sig Too Big
25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Now don't take offense to this paully i'm trying to be tactful but i think your signature is too large and falls outside of SAU's signature guidelines of
now i don't want this to turn into a slinging fest of harassment but keep comments clean and posative
# Combined Text and Image signatures to be kept within 600x200 pixels
# Keep text to within the above dimensions
while im @ work its a full pg up or dwn to just get through your signature
https://www.sau.com.au/forums/topic/180672-is-pauly-sig-too-big/
it dont look so big on my screen at all and im running 1600x900...
The whole point in complaining about a big sig is that it takes a long time to load, but since madaz is being such a big freakin girl about it. I'll change it for the good of the 15 inch LCD hes running SAU on in 640x480 rez.
If you had a problem about it, come to me next time. stop being a bitch honestly. I expect an apology.
-Pauly. (NOTE THE SINGLE "L" IN "PAULY" ASWELL)
Edited by Pauly33GTS-t
yes see, mines all text, but ill change it anyway cause as I said, no one told me about it...
talk about ratting someone out in a different context...
its not like my sig or avatar takes 45 minutes to load on 56k ull find it shows up pretty much in under 0.2ms.
Madaz you right... but you know since ur going down this path.
Your signiature falls outside SAU's limits of 600x200 by being 478 x 275 big.
So. Im changing mine to be within the guidelines, but if the hypocrit that started this thread can also be f**ked, he should change his too.
I think this crap should be locked, and cubes can you edit the title to have "Pauly" spelt correctly. thanks.
I voted for "my cats name is mittens".
Your 100% correct Pauly i didn't start this thread thinking i was above the signature guidelines I've never had anyone complain about my sig.. as yet and am more than happy to review and make necessary changes as seen fit.
and for the most part most people here adhere pretty close to the guidelines but come on man show a little respect
for those interested the screen shot was taken on server 2003 its a 800x600 terminal
your signature is still rather large but its a vast improvement even Pete (ax53b70p25) has done more mods to his car and fits it in a nice compact blurb if you wish to read it
for all those concerned about there sigs im not the sig natzi many of you know i make allot of the sigs you see in the Adelaide section i even made a befitting one for Pauly to which i understand if he doesn't wish to use it
you mean the one that told me to screw his sister as a retort?
Yes id love to spend my time reading his signiature since following by his examples would be worth my while.
You made a stupid signiature for me which i did not wish to use and if you did the right thing we wouldnt be in this predicament.
I'm willing to forgive all and forget but i think that you want to keep going on as some sort of mascarade of bullshit.
now /quit rage please.
Guest
    • Hi, We've all posted some thread, or know of some other person's thread, that contains information that we want to send people who are asking question to. But if we don't have a link readily available, have to go do a search for the thread before being able to do so. So, it occurred to me that we could possibly utilise the auto-text-replace function that fixes some of my swear words to perhaps auto replace some special keywords with text that also has a link to the thread. A specific example. The thread that I did with the improved R32 GTR wiring diagram scans. If the phrase "R32 GTR wiring diagram" could be auto replaced with "R32 GTR wiring diagram" then all I (or @Duncan, or any of the others that refer to the thread) need to do is remember that that's the keyword (or phrase in this case). OK, it would be better if this keyphrase wasn't that long, but it does need to be specific enough that it doesn't get triggered automatically. And obviously there are threads on turbo topics, or suspension topics that we could treat similarly. Alternatively (and/or additionally), I've been thinking about trying to build a library of the real expert content that is trapped in the bowels of the 25odd years of this site. Things like some of SydneyKid's content. There are threads that he started that should be more easily found, and he has individual posts, or series of posts, in other people's threads, containing very good information. Some of us know that it is there, but....just have no memory of exactly where/when/how we saw it. If we had some sort of library thread, we could put posts in there containing links to things we've found, suggestions for how to categorise it, then a mod or other appointed thread maintainer can copy the link and any key text up into the first post in the library thread. There are probably many other ways to get it done. Some sort of wiki is probably the best way.   Thoughts?
    • But, probably that happened to the last person too, which is why the RTV was there.....if you aren't putting a new gasket in you will need to seal the old gasket back to the metal surface with something, the gaskets will generally only work properly for a single use as they set/harden in that shape
    • What is with the horrible blue and white bit in the centre of the wheels, didn't that come off with some scrubbing?
    • Not sure how broadly you define Northside  but Castle Hill Exhaust are still around and could sort it.
    • I haven't done this as I still use the factory cluster, but I do know the circuits for the flash vs on for hi beam are separate which is likely the issue. The ON runs full power through the switch and the flash uses the relay in the engine bay. I'd hit the wiring diagram per GTSBoy's suggestion
