Hey guys,
Just making a post to inform everyone about a good experience with one of our SAU VIC supporters, John from PDR-TEK.
My old lady's car had a decent dint in the rear qtr panel of her Astra, his work was great.. I didn't think he would have been able to get the dint out, let alone get it close to 100%. Looking at the panel now, you would never pick that a dint used to be their.
He did the job at her work and spent a few hours perfecting his work, even helped out another person at her work!
If you sign up to become a VIC member and present your card he will look after you, as he did for me :thumbsup:
If you guys are interested here is his contact details:
John
0419 600 300
http://www.pdrtek.com.au/
Cheers,
Mark.
https://www.sau.com.au/forums/topic/180676-pdr-tek-great-experience/
Good one Mark!
- I was reading the SAU-VIC Sponsors the other day and wondering about this as my new car has a new ding on EACH SIDE! GRRR..
Will have to get this done as well but the dents are really small and hardy noticeable to most people. BUT not to ME! ;D
Can he make the panel back perfect?
haha i know what you mean, nothing worse then getting those first few dints on a new car!
Depending on the access you have to the back of panel and what the dint is like will depend on how well he can get it out. Even if he cant get a dint out 100%, he says he can get it close or would be able to considerably improve it.
Best bet is have a chat to him, or send him some pics so he can let you know.
  TurboX said:
Good one Mark!
Hi guys, thanks for the kind words. As for a perfect finish that is what i aim for. Obviously some dents are just too big or the metal has been stretched, but in most cases i can improve the dent to a point where it can hardly be noticed. Smaller dings and dents i can usually get a perfect or near perfect result.
Cheers
  sammus said:
i bought my car with a few blemishes and they've always annoyed me...
what kinda dollars am i in for, for the average job by john?
Hi Sam, i am sure you can appreciate it is very hard for me to provide a accurate quote without seeing the dent first. If you can send a few digital photo's to info@pdrtek.com.au i can have a look, or have a look at my website here at www.pdrtek.com.au or just give me a call to arrange a time and i can come out and supply a quote. As a very rough guide dents the size of a 5 cent coin will start at $60 for SAU members, if you have a few dents on the same panel then i will discount to do a few dents on the same panel.
Hope this helps.
Cheers
John
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
