Firstly, any help/advice greatly appreciated!
I bought a Nissan Stagea RS4 Neo (2000) Series 2 about 2 months ago from a dealer in Melb. After driving it back from Victoria, and in Adelaide since, on the 2/08 i took it to a radiator specialist because i noticed that collant from the overflow bottle was constantly disappearing after even a days drive, i kept topping it up. There weren't any leaks on the ground where it is parked, oil cap had no milky residue. Anyway, the radiator guy told me i had to replace my top tank, but even more of a problem was my head gasket was on the way out. A week later, i took the car to Boostworx in Adelaide to have a leak test done. It was confirmed that I have a warped head gasket. Now.... I contacted Vic Consumer Affairs last Fri (10/08) regarding the compulsory 3 month warranty that came with the car, and they told me the dealer who sold me the car should cover the repairs. He (the dealer) is trying to say that the warped gasket was caused by the engine running hot, or that i have been driving the car hard. The car has no mods, and my wife drives it 90% of the time. I''m sure the radiator guy told me that the top tank leak was caused by the gasket problem, and even on the receipt stated that the work he did wasn't covered by their warranty due to the gasket problem, and that the same thing might happen again. The dealer is saying that his mechanic told him that Skyline gaskets never fail unless they've been thrashed or driven while hot. So basically he's trying to put the blame on me by saying i drove the car without coolant.
Anyway, i'll be out of pocket over $1600-$2000 if Vic Consumer Affairs can't do anything for the head gasket fix and was wondering which might have come first... gasket problem then top tank problem? Or the other way around. I'm a very careful driver and always keep an eye on the temp gauge.
Thanks very much.
https://www.sau.com.au/forums/topic/180679-problems-with-rb25det-neo/
The mechanic is correct in saying the gsaket doesnt usually blow unless it has been driven whilst overheating, but thats not your pronlem, tell them your going to the department of fair trading if they dont cover it. They should have fixed he overheating problem in the first plae.
Doesnt matter which happened first, they should fix them both. As long as you havnt had it on a race track they have to cover it. You arent meant to check your coolan t every time you drive it in case it had run out.
Well, that's what i thought. Having decided to spend a little more to buy from a dealer, imagine my surprise when i was told i had to spend nearly $2000 more on it!!
  • 1 month later...
Mate, usually a blown head gasket is caused by over heating of the engine which in your case might have caused by a fault in your engine cooling system (radiator, cooling fan mulfunction). Neo6 is a very solid engine and built to handle any sort of beating thrown at it so clearly u r long distance driving couldn't have caused u the mentioned problem... however it could have escalated the problem which would have been there since the day u bought the car from the dealarship. If the car has done over 100,000 Ks u could expect this sort of a radiator problem because in Japan one owner does not own the same car for more than 3-4 years (abt 50,000 Ks) and more Ks on the clock more negelected it is on the maintainance side. I'm a private importer and have imported many NISSANs over the years.
It has approx 80k on the clock. So you're saying more then likely the problem was there before, and became worse after i bought it?
It's been repaired anyway, the mechanic found that the valves had been burnt as well so there was another $600 odd gone too. Hopefully I'll get some if not all back from the dealer. MAtter is with the Vic Consumer Affairs anyway.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
