got my 32 defected the other day by the locals, aparently it was too low but it is running full stock suspension, he done me for a r32 coupe specs which is 360mm all round from the centre of the wheel to the eye brow on the guard, i have since bein told that a r32 sedan sits lower than a coupe so if any one knows what the spec is for a sedan it would be very helpful as i got no way on this earth gettin it to sit that high
https://www.sau.com.au/forums/topic/180706-r32-legal-ride-height/
This eyebrow bullshit again.
You're in South Australia right? I'd really love to know if this is a legal measurement as it certainly isn't part of the ADR's. Things like ground clearance, head light height, high mount brake light height all must conform to minimum heights off the ground, but center to guard measurements?
Can you fight it and say that your car isnt a coupe its a sedan, and that the sedans sit lower?
Does the car actually sit lower or are the guards lower? When i had my VT wagon i found out that the rear guard was lower than the sedan ones, maybe same kinda thing here?
This is from SA TRansport legislation:
Transport SA has a list of acceptable suspension and eyebrow heights (the measurement from the centre of the
wheel vertically upward to the edge of the mudguard) for most passenger vehicles and can be contacted to
verify if the ride height of a vehicle is within acceptable limits.
but, in the next paragraph:
Raising of the car is not recommended due to the cornering instability that may result.
How fn stupid is that?
Out of interest, do they actually measure the height of the car off the ground? Could you, for example, get some custom guards that sit the wheel arches higher and then have the ride height below 100mm and be legal?
This is from an oldish set, but there is an ADR (ADR 43/02) covering ground clearance:
43.4.4 ‘Ground Clearance’ The ‘Ground Clearance’ of a vehicle, other than an L-Group vehicle [Motorbike / Moped], measured from a horizontal road surface to any point on the underside of the vehicle except the tyres, wheels and wheel hubs shall, under the conditions of ‘Maximum Loaded Test Mass’ loading as specified in the relevant braking Rule, be not less than:
43.4.4.1 for any point in the width of the vehicle which is within one metre fore and aft of any ‘Axle’, 100 mm;
43.4.4.2 for the mid-point between any 2 consecutive ‘Axles’, the dimension in millimetres obtained by multiplying the distance between those 2 ‘Axles’ in metres by 33.33; and
43.4.4.3 ...
hey guys, this is in regards to my 32 (cheers soslo :thumbsup:
yeah got defected for to low, when i had it at work to bled brakes everything is still factory etc, and when soslo took it dow for inspection, they used 2door specs, that wasaslo 91 onwards.. (its a 89 lol)
so yeahi could fight it on a couple things, i dont wanna go buy another set of springs when ive got a set of coilovers on the way...
and yeah, the guy that does inspections down here has NFI what his doing, stock factory BOVs are illegal apparently.... lol
dont blame ya man
on ns.com every 2nd thread in the sa section is about a stolen r3*
still, if anyone has any idea what the stock height is for a 4 door, please let me know, tried calling regency but didn get through
tempted to chuck coilovers in, and see if i cna use them to get through....
***qucick edit, im assuming "eyebrow height" is centre cap of rim to guard???
Edited by driftrx
  • 2 years later...
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
