Hi guys,
I own R33 Series 2 (12/97) and i noticed that its making a bit of noise, noise is not coming from the engine itself i think, when i press the clutch it stops,its sort of a whistling noise. Its not making any noise while i am taking off, and gear changing seems smooth, i bellive its not gear box. I am suspecting a clutch, or is it normal? ( i only had it for 3 months) car has done 97 000 so i am not too shore ...
Dose anyone know anything about it?
Any ides?
Thanks
https://www.sau.com.au/forums/topic/180715-noise/
that would be your thrust bearing champ, its the bearing that presses against the clutch pressure plate when you put your foot on the clutch. its either that or a bearing in your gearbox is on its way out.
Hi,
Thanks for your reply pal
it is most likely that bearing in the clutch, i wont tuch it for some time, apperently its not a big issue ... i'll c how i go ...
One more thing, Central door lock switch,do u lock 2 or 1 door when u press it???
One of the blokes installed the alarm the other day, and since then i only lock pasenger door when i press it, is it supposed to lock driver side ...???? or is it just me tripin that i was able to lock 2 at the time, i dont remember ... LOL
if i use the actual button on the driver side it looks everything, but i am just wondering about the actual switch
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3287898
if you are saying what I think you are saying you have the same problem with me and my R32. If I arm the alarm it will only lock the passangers door not the drivers door. If I use the key in the drivers door it locks both passangers and drivers door. I am guessing maybe they wired the alarm up to a wire running to do passangers door which I dont think is a master in the central locking where it should be running to the drivers instead. Although that is just a theory.
Edited by Triptych
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3287975
Mine shits me to tears. Its becoming so loud im almost tempted to do it. Problem is like posted, clutch should be done at the same time.. thats the bit my pocket cant fund at the moment!
Im interested to know why some make noises and some dont. I've read up on thrust bearings a little bit but havent had any success finding this kind of info.
Cheers
Edited by Yidz
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3305431
Really interested in the whole central locking thing,
i have a 95 r33 s2 and it only locks my drivers door when i push the button.
its not a huge probem but passengers have to lock their door when they get out or i have to lock in using my door buttons.
can this be fixed easily as everynow and then both doors will lock but very rarely. not sure if its an electrical problem or the gears in the door might be stufffed?
just wandering.
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3305680
Cheers
Hi,
Well i guess that reason y they become loud is just general weare n teare, no bearing will last 4ever, they dont like shocks, what happens when u drop the clutch ... the whole transmision suffers, n the clutch is the weakest link .... Some of them stress more some less, those who stress less will prob last longer ...
Its not much of a concern, i know its anoying but ... it dosent bother me that much, when the clutch is gone i will do it then ...
The central locking, man i have no idea, when u push the button u lock driver side only??? mine only locks pasengers side WDF??? i dont get it, but my central locking locks both, which is ok ...
Its not a big deal anyway, maybe its supposed 2 be that way ...
This is the only Skyline bit that i dont like, all day every day worry, whats this whays that, is it supposed to be that way, is someone gonna scratch it or steal it, or am i gonna get defected for this or that, i am becoming a skyline zombie
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3306754
For the central locking thing - On a stock car, the passenger side has a relay and motor that locks/unlocks the door when the drivers lock is activated with the key. When a central locking remote is added, you need to add a motor to the drivers door as well, so it also can be activated electronically like the passenger door when you hit the remote.
I would assume that the motor wasn't put in drivers door or it has been wired up incorrectly, so it does the weird things you guys are mentioning!
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3311937
