Hi guys,
I own R33 Series 2 (12/97) and i noticed that its making a bit of noise, noise is not coming from the engine itself i think, when i press the clutch it stops,its sort of a whistling noise. Its not making any noise while i am taking off, and gear changing seems smooth, i bellive its not gear box. I am suspecting a clutch, or is it normal? ( i only had it for 3 months) car has done 97 000 so i am not too shore ...
Dose anyone know anything about it?
Any ides?
Thanks
https://www.sau.com.au/forums/topic/180715-noise/
that would be your thrust bearing champ, its the bearing that presses against the clutch pressure plate when you put your foot on the clutch. its either that or a bearing in your gearbox is on its way out.
Hi,
Thanks for your reply pal
it is most likely that bearing in the clutch, i wont tuch it for some time, apperently its not a big issue ... i'll c how i go ...
One more thing, Central door lock switch,do u lock 2 or 1 door when u press it???
One of the blokes installed the alarm the other day, and since then i only lock pasenger door when i press it, is it supposed to lock driver side ...???? or is it just me tripin that i was able to lock 2 at the time, i dont remember ... LOL
if i use the actual button on the driver side it looks everything, but i am just wondering about the actual switch
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3287898
if you are saying what I think you are saying you have the same problem with me and my R32. If I arm the alarm it will only lock the passangers door not the drivers door. If I use the key in the drivers door it locks both passangers and drivers door. I am guessing maybe they wired the alarm up to a wire running to do passangers door which I dont think is a master in the central locking where it should be running to the drivers instead. Although that is just a theory.
Edited by Triptych
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3287975
Mine shits me to tears. Its becoming so loud im almost tempted to do it. Problem is like posted, clutch should be done at the same time.. thats the bit my pocket cant fund at the moment!
Im interested to know why some make noises and some dont. I've read up on thrust bearings a little bit but havent had any success finding this kind of info.
Cheers
Edited by Yidz
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3305431
Really interested in the whole central locking thing,
i have a 95 r33 s2 and it only locks my drivers door when i push the button.
its not a huge probem but passengers have to lock their door when they get out or i have to lock in using my door buttons.
can this be fixed easily as everynow and then both doors will lock but very rarely. not sure if its an electrical problem or the gears in the door might be stufffed?
just wandering.
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3305680
Cheers
Hi,
Well i guess that reason y they become loud is just general weare n teare, no bearing will last 4ever, they dont like shocks, what happens when u drop the clutch ... the whole transmision suffers, n the clutch is the weakest link .... Some of them stress more some less, those who stress less will prob last longer ...
Its not much of a concern, i know its anoying but ... it dosent bother me that much, when the clutch is gone i will do it then ...
The central locking, man i have no idea, when u push the button u lock driver side only??? mine only locks pasengers side WDF??? i dont get it, but my central locking locks both, which is ok ...
Its not a big deal anyway, maybe its supposed 2 be that way ...
This is the only Skyline bit that i dont like, all day every day worry, whats this whays that, is it supposed to be that way, is someone gonna scratch it or steal it, or am i gonna get defected for this or that, i am becoming a skyline zombie
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3306754
For the central locking thing - On a stock car, the passenger side has a relay and motor that locks/unlocks the door when the drivers lock is activated with the key. When a central locking remote is added, you need to add a motor to the drivers door as well, so it also can be activated electronically like the passenger door when you hit the remote.
I would assume that the motor wasn't put in drivers door or it has been wired up incorrectly, so it does the weird things you guys are mentioning!
https://www.sau.com.au/forums/topic/180715-noise/#findComment-3311937
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
