Hey all, I'm Regretfully stepping out of my Skyline into something more a little cheaper to pay off some debts.
Specs as follows:
YEAR/MAKE/MODEL
1997 Nissan Skyline GTS25-T Sedan
ENGINE HARDWARE
Nissan RB25DET Twin Cam Turbocharged 2.5 In-line 6 83000kms Serviced Every 5000kms using Genuine Nissan Filter and Mobil 1 Oil
ENGINE ACCESSORIES
Just Jap 600 x 300 x 76mm Front Mount Intercooler Kit
Blitz BOV
GReddy Profec B Boost Controller (Very rarely run at 11psi, usually switched off)
DRIVETRAIN HARDWARE
Nissan 5 Speed Manual
BRAKES & SUSPENSION
Front: Nissan(Sumitomo) 4 Pot Monoblock Calipers with Standard size RDA slotted rotors, Bendix Ultimate brake pads
Rear: Nissan (Sumitomo) 2 Pot Fixed Calipers with Stock size RDA slotted Rotors, Bendix Ultimate brake pads
Jaguar DOT4 Brake Fluid
G4 Racing Street Spec Coilovers with 20% softer inserts
ROLLING STOCK
STREET
17"x7.5" Nissan R34 GT-T 6 Spoke Alloys
225/45ZR17 94W Falken FK452 Rubber - 2 need replacement
BODYWORK
Standard Nissan Sonic Silver
Front Bar modified to fit FMIC
INTERIOR
Stock Interior
Leather wrapped steering wheel
Nismo leather gear knob
STEREO COMPONENTS
Pioneer Bluetooth CD Player with Ipod adaptor (keeping that for my next car, will be fitting another unit or reduce the price accordingly.
Stock Front speakers with Fusion Tweeters :S
Pioneer 3 way 6x9's
PERFORMANCE
1/4 Mile 14.2@ 98mph @ WSID
156.4RWkW (using Dyno Dynamics Shootout mode)
I am the first Australian owner since buying it off a compliance workshop in November 2006. Its been nothing but a pleasure to own, great car to drive, especially on the open road. Every thing that u expect feature and performance wise from a Nissan Skyline with the ability to take the family or friends along for the ride! Am willing to remove certain items (Boost controller)
Rego till 20 November 2008
Chasing $15500, Headunit will be removed and a new headunit will take its place or negotiate without stereo. This is a Genuine and regretful sale. No Timewasters, no Joy Riders and no Test pilots please.
Will Trade for cheaper car/ute or 250cc motorcycle plus cash.
Bump. Regretful Sale. Price seem a bit high? I'm trying to filter out time wasters and low blow rediculous offers.
Forgot to mention, no joy rides, test pilots, timewasters
BUMP! Now on carsales, Mention SAU and I'll be more flexible on price, really want to sell it to someone who will look after it as much as I have.
Link: http://www.carsales.com.au/pls/carsales/...icle_id=4601620
  • 4 weeks later...
  • 1 month later...
Update: Price is up to $16750 as i have renewed the Rego for another year!!!
Wil Consider trades for S13 180SX with SR20DETplus cash Adjustment or straight swap N/A R34 Non turbo manual coupe
  • 1 month later...
Massive Price Drop! $15500, willing to trade for cheaper car/ute or 250cc bike plus cash.
needs 2 front tyres as they have camber wear.
Circumstances have changed and it MUST GO!
Come on guys/gals, surely you know someone after a clean well maintained Skyline, mechanic owner. This car has never let me down, need to sell so i can move out of home.
Make a reasonable offer. tell your friends, its a great car, but i wanna fulfill my dream of owning a Zed and i have a motorbike on the way.
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
