Hi Guys
Well i have this funny Clunk Noise on start up, especially when cold, it's like when the engine is just about to fire, it sounds like a pipe or something is hiting something else, and making a hollow clunk sound.
The noise, sounds like it comes from the pasanger side of the car, but when i open the bonnet, i can't hear anything when i start it up, it sound normal, so i presume it's under or at the back of the engine.
I have looked at the engine mounts, all good, no cooler pipes hitting anywhere that i can find, engine runs great, no noises or anythign else other then this.
Once the car is warm, the sound is not there most of the time, i presume that is mostly as the engine is a lot easier to start when warm.
There are only 3 or so clunk noises when you start it if you know what i mean, not an on going sound.
It doesn't sound mechanical, more like a screwdriver hitting the top pf a plastick bucket, exactly like that.
Any ideas what to look out for???????????
https://www.sau.com.au/forums/topic/180730-funny-clunk-noise-on-start-up/
Yeah i checked that, the engine doesn't actually move when you start it much, and i certainly can't move the engine in either direction when off, looking arround the mount, it appears fine, no cracks. Will double check though.
Sorry to hijack a thread. Sometimes when in neutral, shift into reverse, give it some gas and it does this clunk sound. But its in the back or somewhere under the car. My ideas : driveshaft/subframe or gearvox moving ? Anyone had something like that before ? Thanks!
  • 4 months later...
    • Looking for a S2 front grill for an R34 GT/GTT Doesn’t have to be in excellent condition as I’m looking to paint it. Would preferred if the clips were around.    The $500 this marketplace guy is asking sounds ridiculous in my opinion.
    • Nah, just take the other one off too
    • A mini mini-gun.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
