Hi Guys
Well i have this funny Clunk Noise on start up, especially when cold, it's like when the engine is just about to fire, it sounds like a pipe or something is hiting something else, and making a hollow clunk sound.
The noise, sounds like it comes from the pasanger side of the car, but when i open the bonnet, i can't hear anything when i start it up, it sound normal, so i presume it's under or at the back of the engine.
I have looked at the engine mounts, all good, no cooler pipes hitting anywhere that i can find, engine runs great, no noises or anythign else other then this.
Once the car is warm, the sound is not there most of the time, i presume that is mostly as the engine is a lot easier to start when warm.
There are only 3 or so clunk noises when you start it if you know what i mean, not an on going sound.
It doesn't sound mechanical, more like a screwdriver hitting the top pf a plastick bucket, exactly like that.
Any ideas what to look out for???????????
https://www.sau.com.au/forums/topic/180730-funny-clunk-noise-on-start-up/
Yeah i checked that, the engine doesn't actually move when you start it much, and i certainly can't move the engine in either direction when off, looking arround the mount, it appears fine, no cracks. Will double check though.
Sorry to hijack a thread. Sometimes when in neutral, shift into reverse, give it some gas and it does this clunk sound. But its in the back or somewhere under the car. My ideas : driveshaft/subframe or gearvox moving ? Anyone had something like that before ? Thanks!
  • 4 months later...
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
