Hey guys, just wanted to ask a question about when I start up my recently turboed R33 GTS4 (rb25deT)
I got it dynoed now and got the timing fixed up, it is running rich, but a powerfc or something alike will fix that,
Problem is when I start to drive the car in the morn and it is cold, I'm finding that at about 5 grand it is sounds like it is missfiring, it wont go past bout 4,800 - 5,000.
When the car is warm she is better, still finding when you want to get it in the high revs that she hesitates for a lil, which it didnt when it was an N/A.
I dont know what it is,because as I said the timing was fixed up and new sparks, which were gapped correctly.
Is this a turbo thing or do I need to fix up sumthing?
Thanks, Adam
https://www.sau.com.au/forums/topic/180744-problems-on-start-up/
it is probably your coils aren't able to keep up with the job. try and borrow someones coils and see if that gets rid of it. if it does then you need new coils.
also, find out what sort of plugs were used, with what gap and what heat range.
LOL.... I was just waiting for somone to say it is stupid to push her first thing... but when u live on a main road and trying to get out in morning traffic.....
but that still doesnt explain when the car is warm and at 5 grand.. why it is still a lil hesitant
so coils then? hmm... as this is my first car everything is new to me.. could anyone point me in the right direction? places to buy? etc... anything is handy!
Cheers,
Adam
well split fires are a dirct replacement coil thats gives youa few more horspower, negun.com have splitfires for 500 buck delivered to ur door or try a local jap wreckers they range from 110 to 150 depends on wrecker and what series the car is one is a little cheaper than series 2
Thanks for the help guys, I would have thought the current coils would handle alright... unless do turbo skylines have more powerful ones?
Im only getting roughly 150-160 rwkw + 10-20% at front so max would be bout 170 - 180 awkw all up.. you wouldn't need $500 coils yet would you?
thought my fuel pump would go before anything
Hey guys.. update...
The miss firing is also when the car is at operating tempurature.
I did find it wierd when the car got dynoed roughly 3 days ago and there was no missfiring, but I figured out why when doing a few tests...
NOTE: The missfiring or whatever problem is happening starts at bout 5 grand
1. It happens when I drop a gear and put my foot down..
2. It happens when I put my foot down in any gear..
3. It DOESNT happen when I slowly rev the car up...
Which is why when the car was on the dyno and it was powered up slowly why it didn't do anything.
Does this change anything? am I still meant to be looking for coils? any good reccommendations on brands?
Thanks, Adam
After 2 hours on a dyno my car was fine on stock coils.
on the road it misfired
to fix it the plugs were gapped down to 0.6 then more dyno....
but i'm still getting new coils when the new turbo goes in.
So basiclly new coils are the only way out of this? cuz at first the turbo conversion was a bargin.. now everytime I fix up one thing the next happens!
Im happy with the power gains.. but can 33 gtst's use other engine coilpacks?like ... 34 gtr's ? or 32 gtr's...etc...
GRR... Annoying little things these are.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
