Hi Guys,
For sale is a Greddy STYLE (NOT GENUINE) Inlet plenum I bought off Ebay.
I have fully ported it and beed blasted it and it is 100% ready to bolt onto a car.
if any one has bought one will know that they are no where near ready to bolt on to car as they come.
I have spent over 8 hours getting it ported by a proffesional porter (usually does car heads)
it has come up really well inside the ports and should flow well.
I have not touched the out side so it still looks a little messy.
it has also had the water neck inlet modified so it fits properly.
Most threads have also been re tapped to make sure they are good.
Comes with mounting kit that it came with from Ebay.
I paid 250 + 25 frieght and have spent a small fortune on it with the porting.
I would like $300.00 dollars for it and buyer pays frieght if out side of tasmania.
if you have any questions please dont hesitate to call me on 0406 270 490 or email blake@jds-auto-imports.com
Cheers!post-18222-1187048862_thumb.jpgpost-18222-1187048935_thumb.jpgpost-18222-1187049274_thumb.jpgpost-18222-1187049301_thumb.jpgpost-18222-1187049344_thumb.jpg
Edited by tazgtr
https://www.sau.com.au/forums/topic/180747-sold/
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
