Lol ok dude...
Also for those who are getting a pump because their car was dyno'd and running lean.. we should try organise something with a shop to get our cars re-dyno'd to make sure everything is ok. Maybe if we organise a day to install we can do that in the morning and get the car's Dyno'd that afternoon?
I might be interested. Just deciding whether or not its worth me getting one now as im really only running a stocker GTS-t. Would you say its worth getting one or not until im perhaps running more boost or have more extensive mods?
Well I wouldnt be getting one except I got a dyno done and my car is running lean due to my pump is dying.. it is over 10 years old now. I'm on stock boost aswell.
Have you had a dyno done with your air/fuel ratio's?
If you wanna grab one we're gonna install em together on a weekend.. should only take a few hours to get them in. But if you want to wait and get one later that's no worries man, any shop can install them or we'll help you out.
I just got paid so I'm ready to order mine :action-smiley-069:
depends on how soon and what mods you plan to do, my stocko pump was running an safc, front mount, and exhaust, then it packed in cuz of time..not cut it couldnt handle it. its something your gonna have to change eventually. but all in all depends on your needs for the future.
Alright thanks. I kind of considered that yeah eventually im going to have to replace it sooner or later, but id rather get my front mount and front bar first. Ummm ill confirm my decision later tonight, so I'll send ya a pm tonight if I decide to get one and we'll take it from there. cheers.
  • 8 years later...
Hey guys, I stumbled across this thread and was wondering if I could still pick up the tomei fuel pump kit for my 32 gtst?
i think i seen a few online for around $380 excluding shipping, any chance picking it up any cheaper?
Thanks
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
