  • Replies 273
rightio gents and ladies(thats you shane), as someone who has embraced DRIFT, you drag racers are just jealous that we get to turn RIGHT as well as LEFT.
u own an rb20, ur opinion doesnt count :P
Nigga please
I can drag to a degree
I can drive circuit to a degree
But I can not drift in anyway shape or form
That tells me it is harder and the likely hood of tards being able to do it is low
And Noel you KNOW that when done well and minus the antisocial skater/jackass type attitude that the scene has in this particular country it is a good specticle with some really nice cars! You told me ooops I promised not to tell others ha ha :P
haha cats out of the bag..
im just a beginer too. getting faster and more confident its pretty scary the first time.. practice makes perfect like the 50 times u run down the track to get ur 60ft down.626632737_l.gif
that isnt me.. i wish lol.. beautiful 240sx
Hands off the wheel Mudcrab!!! It will actually go straight if you leave it alone. :laughing-smiley-014:
im not getting it.. nomuken..
again.
Looks like a car hitting an apex to me...at speed...and in control......all while hazing them, better to watch and one additional skill involved compared to garden variety track work, SKIDS!
Looks like hes totally f**ked up and out of control to me. About to be overtaken up the inside by half the field. :P
a motor is only a tiny bit of the project.
now compare the 2
hang a sec is shane saying that his engine isnt the most important aspect of his car!!!!!!!!!!!!
and i do have the rest covered shane
ahahahaha.. thats what u do initally noel.. u power out hands off the wheel let her correct herself and get back on that wheel and keep it angled.
bahaha....003.jpg that is kazama aka rodeo clown of D1 from kei office. taken under the wing of tsychia himself. perhaps uve heard of him noel.. :thanks:
Didnt he play fulll back for Cronulla?? :P
Guest
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
