Just noticed on shitehouseNS.com that the Toyota Car Club are putting on a Nissan v Toyota Dyno Day at Boostworx on the 15/9
Soooooo calling all HIGH KW Skylines........LOL Munro, Darren, Darren, Matt, Dan and the rest of you, get the cobwebs off and roll down, i think i'll be there but just giving you guys a heads up!!
Link below
http://www.nissansilvia.com/forums/index.p...howtopic=252401
It starts at 10am and finishes up at 5pm.
Register with the www.toyotacarclub.net forums and then proceeded to register your intent to run with the details of your car (brand, make, model) at the following link.
http://www.toyotacarclub.net/forum/YaBB.pl?num=1186751226
Doing so enables you to get the dyno run for $35 vs $40.
https://www.sau.com.au/forums/topic/180801-nissan-v-toyota-dyno-day/
  • Replies 105
Add to that list snyper and hostile if we can get them out there.
I should be making over 210 RWKW by then as well, but i suspect that will not be anywhere near enough kw's to make any competition.
I'll be there (well, stagea anyways) on the monday 10th for final tune n stuff.
200awkw Id expect........ around 1 or 1.1bar
then thrusday 13th out comes the last (left) kneecap + high tibial tubercle osteotomy
so, on that note, have fun on Saturday 15th as I know I sure wont be (havn fun that is)
hopefully be there. might even put the 32 up for a run. hoping for 250rwkw + by then. depending on what my car has on it eg injectors and fuel pump.
dyno very shortly to find out once the return from jesters with turb installed.
Link below
am i one of those Darrens?
just put 323kws at Boost worx this morning.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
