i was
Adz raises hand to organise mini cruise
yeah i will see if i can afford to put it on hopefully can we will need a few good nissans if they happen to find some good 2JZ's
lol i would organise something except i get lost leaving my own street!
  • Replies 105
yeah im not going now also :D have to decide do i goto dyno day or bring daughter home and to bed so i can take her to the royal show again and see the fire works
me thinks take her twice her mum will only take her once :D gooooo dad :(
hahaha... Not only the box but the clutch flares also. :D
You going to get the muppet bus on the rollers Darren?
I seriously looked in to an auto conversion for a little there, MV had an auto for $350 + 220 for full manual $300 something for shift kit.
UNTIL...
I stumbled upon an Rb25 5speed out of a crashed series 2 gtst for $950 with tail shaft included.
I had to rip the box out which was a nightmare due to the tunnel being compressed slightly. The box is in perfect nick; so I will be staying with manual and having some fun with the car around Mallala AND the drags once/when it opens back up.
Keen to go halves in a pair of slicks when the time comes Darren? :D
hahaha... Not only the box but the clutch flares also. :yes:
UNTIL...
Keen to go halves in a pair of slicks when the time comes Darren? :)
yep more then keen.
and yes i will be there.
But we will need to have a set each to run each other,
unless your happy running on street tyres.
Each have a run with street tyres. See who gets whooped worse. :)
2 slicks aren't too expensive anyway.
BIG thanks to Madaz for popping around and giving me a hand to get that damn box out!!!!!!!
[quote name='Cubes' date='10 Sep 2007, 08:41 PM' post='3338929'
Each have a run with street tyres. See who gets whooped worse. :)]
i would have traction issuse up to around 100kph where you "may" get in front.
Edited by dangerman4
hahah.
As long as you don't do something silly like bolt on a water/meth injection kit I think it will be close..... for you. hahah :)
im guessing by that you have a WM kit on its way?
Me Silly?
what should i bring to the dyno day?
my wifes skyline or my atv?
cant bring both, and i would find it rather amusing my quad having more power then some of the cars there.
hahaha... Not only the box but the clutch flares also. :)
UNTIL...
Keen to go halves in a pair of slicks when the time comes Darren? ;)
damn, i thought i did oright finding mine for $1200 and i still need to find a yoke.
Found someone to do the tailshaft mod yet?
Yokes can be picked up for ~$110.
Haven't sorted the tail shaft mod yet.
Just sorted the speedo drive and will be dropping the diff ratio down again to help prevent wheel spin in the first 2 gears.
Prior when I ran the 4.08 ratio second gear felt lazy as there wasn't quite enough balls; first felt great much more usable; now third has issues depending on road surface and how hard/quick I flatten it. So I think the 4.08 will be welcomed, if not more boost. ;)
I am running 225's though so thats to be expected; but the 225's do hook a little better than a mates set of 245/40/18 Nankang NS2's.
Peoples...
Anyone that registers for entry before the event will get to dyno for $35.
Follow the link ---
http://www.toyotacarclub.net/forum/YaBB.pl?num=1186751226
Post that you will be attending and with what car (brand, make, model).
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
