Hi,
I have an issue with my R34 and a rough idle. First a run down of the mods on the car:
1999 R34 GT-t
Apexi Power FC
HKS Dump/Front/Exhaust
HKS Pod filter
HKS turbo timer
Cold air box
Hybrid FMIC
Exedy Clutch
C's short shift
The rough idle appears to happen randomly mainly on start, at any time, cold start or warm start. However it has dropped in to a rough idle in the middle of driving it as well... some time after starting it when idling at the lights. When it does this the car runs very badly and shakes. I don't like to do it, but I can 'drive' the bad idle out by giving it some revs in second, however I cannot seem to rev the problem away in 1st.
The car's just been serviced and the plugs have been replaced. I am hoping I am not losing a coil or worse. I believe it is in need of a tune after some mods, however, it is not a new PowerFC and it has been tuned before(just not with some of the newer mods) AND it had this problem before the new mods(In fact the new mods seem to have improved the issue, perhaps thru better air flow). If it helps, the new mods are the HKS exhaust(turbo back), Hybrid FMIC, cold airbox, Exedy clutch and C's kit(not that the shift kit should cause any problems! :))
I have searched fairly extensively on the forum but with no luck as to my specific problem. Any help would be appreciated.
Cheers.
https://www.sau.com.au/forums/topic/180804-ocassional-rough-idle/
Try giving your Aac Valve a clean
http://www.skylinesaustralia.com/forums/in...howtopic=110431
Mine had the same problems with rough idle as you described.
Would sit around 600rpm on idle and had to keep my foot on it.
Gave the Aac and my Afm a good clean out and she runs so smooth now.
hope that helps you
Thanks Sly... I think you may have something there. I will give it a go. What I didn't mention in my post is that I also get some clutch/low revs shudder as well which you said was fixed by AAC clean. I thought it was my new Hyper single clutch causing the issue...
Can't wait to see the result.
AAC didn't help me. I'm going to give my cold start valve a go
Not sure cold start valve will apply to me as it is happening to me when the car has warmed up as well. If AAC clean doesn't work I will give it a go though... up for anything. Thanks.
Same as mine. My idle is rough always - hot or cold. I was just thinking that since I've already done the AAC and it didn't help, the cold start valve is the next thing for me to clean.
My aac was black inside, but it wasn't jammed or anything. After cleaning it, it was spotless, but it didn't change anything - which means it was working fine to start off with.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
