Guest Des5001
hey all, i done a quick search and couldnt get much out of it, im a basic person when it comes to cars.
my r33 was running on 12psi fine when i got it, i crashed it got it back, boost control is still the same as what i no unless the repairers played with it so i turned the boost up and it dont matter how high i turn it up the boost wont go pass 7psi!
i smashed the front end into a fence and had to get a new intercooler. i think maybe a boost leak? anyone got ideas on what i can do at home to fix it, i live in orange so no one round here can play with it. do u think its best to take it to sydney?
https://www.sau.com.au/forums/topic/180822-boost-problem/
Guest Des5001
i never played with the boost before i crashed it, i think the standard dual stage boost is working, 5psi - 7psi, im not to sure as im goin off the standard gauge in the dash, it sits on the half way line between 0.7bar and 0 so thats 0.35bar which i think is bout 7psi it does move a little bit sumtimes so i guess thats the standard boost settings working, it used to get right to the 0.7bar mark, thanks for all ur help.
here are sum pics
Edited by Des5001
https://www.sau.com.au/forums/topic/180822-boost-problem/#findComment-3287775
Guest Des5001
if the solenoid is the silver thing with 2 tubes goin to it and one free, then there is one on the top and one on the bottom, leaving the middle one free, my cousin has a r33 and on his the top one is empty and the middle one has sumthing on it and his is goin well, maybe thats it, ill try it tomora, ill swap them and see how it goes, thanks for noticing that, hope it works
Edited by Des5001
https://www.sau.com.au/forums/topic/180822-boost-problem/#findComment-3287812
Guest Des5001
if i turn the boost as far as it goes on high and low as it goes on low and use the switch to switch between its makes a difference in power and how quick boost is gained but it wont pull pass 7psi still, i put my cousins boost controller on which is working fine and is set on 13psi in his car and when it was in mine it was still only pullin 7psi! got no idea, wanna fix it bad
https://www.sau.com.au/forums/topic/180822-boost-problem/#findComment-3288003
So what actually happens when you hit 6PSi?
And is this just off of the stock guage it's hitting "7"?
Put an aftermarket boost guage on.
You could be maxing the stock boost guage out (The sender unit)
Edited by MBS206
https://www.sau.com.au/forums/topic/180822-boost-problem/#findComment-3289990
NEVER trust the stock gauge, never ever. They are slow to react, and not accurate at all. Go get a boost gauge, even if you borrow one and just run a vacuum line from under the bonnet to the inside of the car with some one keeping a careful eye on it.
Does the car feel slower? If you were running 12psi before and it is actually only running 7psi now, you will notice a big difference.
Dont start adjust the boost controller with out a gauge to keep track, you could be running 20psi for all you know, especially if you dont have boost cut.
Everything is connected as it should be according to the photos, as long as the wires are connected properly to the switch inside your car it should be all good.
Even if the wires werent connected properly, you would still have a low boost adjustment since this is a dualstage.
https://www.sau.com.au/forums/topic/180822-boost-problem/#findComment-3290004
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
