the way the solenoid is setup won't really make a difference. above 4500rpm it will let a TINY bit of air through into the intake, but it wouldn't cause this problem.
take the dump pipe off and have a look at the exhaust wheel, and take the intake pipe off and have a look at the compressor wheel. also pull the cat out and see if it's blocked.
Guest Des5001
this weekend i will ask my cousin if its ok to swap turbos and just see if its that, if its not the turbo ill pull the exhurst apart. could it be anything else, eg BOV or seals of sum type i just wanna no everything it could possible be so i can play with it all over the weekend, thanks heaps
Edited by Des5001
If it was my car, i would be looking at the boost controller first. I doubt its an exhaust blockage, if your car was running 12psi before and you had a smash it wont just magically block it and restrict your boost to 7psi.
Personally, i would disconnect the hose that goes to the wastegate actuator, put a screw in the vacuum line so it doesnt leak and take it for a VERY CAREFUL spin. The car would be running open boost and if you just floor it it will spool up to 20++psi and you will most likely smash the rear wheel off, but you can control boost by throttle position (as you would of noticed during daily driving), so take it for a spin with the gauge connected and see if you can SLOWLY accelerate and get the boost up around 10-12psi. If it spools up fine then its the boost controller...
Guest Des5001
ok i disconnected the line to the wastegate actuator and boost when up passed the 7psi mark, but soon as i got to bout 8-9psi a loud squeal came in, sounds like belts slipping but my guess is that its a boost leak, that right? since i put my cousins boost controller on and it didnt make a difference i no its not the controller and i no its not the turbo or exhurst so its must be piping for the intercooler or even a dud intercooler???
Edited by Des5001
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
