Hey,
Just want to know, what are peoples thoughts on the advantages of a flywheel? Do you guys believe there are any power gains to be made on a dyno? From what I've read there is no dyno difference however on the street, it is like having 101lbs less weight on the street???
Cheers...
  • Replies 59
Posted Images
also depends what you want the car for. Some like the lightweight one that will rev good... but it does lose some power from revving so easily as there is no momentum behind the flywheel, if you have a dogbox or a very heavy clutch might also be better to get a chromolly flywheel that is heavier for the added strengh
ALSO... if you are replacing the clutch too might be best to get a flywheel clutch combo cause different compound clutches n flywheels will make it slip or chatter. Big writeup a few issues ago in HPI
Edited by choku_dori
Yeh, i gotta replace the clutch now its slipping a fair bit. I'm looking at getting the nismo sports clutch kit, and the flywheel works out to be $350 extra. I heard the other way around, that because the flywheel is lighter, makes it easier for the power to be transmitted through the drivetrain and to the rear wheels, in the end leading to better power to weight ratios. On the dyno figures would be minimal but on the street was told acceleration changes significantly??? Is this true?
a big rock takes longer to gain speed when rolling, but harder to stop once rolling than a smaller rock.
rough example. When a car is in 1st gear engine sees maybe 200kg in 2nd 500kg 3rd900 and so on. If you can remove weight before the gearbox and diff (torque multiplers) you engine sees less weight and can accelerate faster for the same power.
So you won't gain power on a dyno but you will gain response on the road.
You will find that it will rev faster and will be great for the street / track/ and drags, butyou loose torque because it's lighter and doesn't have the momentum to keep spinning which is what you want then drifting and rallying.
I lightened mine when getting a new clutch. I believe this is how it works, tell me if I'm wrong. While you don't get any extra power, if you have 230rwkw (and let's say that's 280atf), then with a lightened flywheel, you'll still have 280atf, but you might have 234-235kw actually reaching the tyres because less energy is lost in the drivetrain. When I got mine installed, I accidentally redlined it in second the first time I planted from a dead holt to 100kph, cos I was used to changing by feel and timing, but because the engine went through the rev range quickly, she bounced lol. I like the feel of it, in fact so much that I'm interested in lightening other parts of the drivetrain to get more of the power I'm already making to the ground. Seems like a relatively cheap way to maximise use of the powr you're making and I plan to go nuts later RE power, so I will want to do it sooner or later.
no power gains as such but the less weight your engine has to turn eg flywheel and clutch assembly, gearbox, tail shaft, diff, wheels the quicker it can accelerate.
Remember gran turismo you could get a racing flywheel and carbon fibre tail shaft and you drop .3-.4 off your 1/4 mile time on a stock s13 or similar!
Well if it is in gran tourismo it must be true.
In reality a kilo or so in amongst 1500kg of car is undetectable. In no way is a lightened flywheel either a significant gain (as some would have you believe) or a loss (As other argue).
The only time you will ever motice it is when the clutch is in. The reduction in inertia allows the motor to pick up and/or drop revs more quickly. You may also notice the lesser amount of inertia when you drop the clutch.
Edited by djr81
Yes, it's more noticeable in neutral and just free revving it, but I've got a buttload of sound deadening and a big sub box, and I could PLAINLY tell the difference during normal driving. I could accelerate faster - It was night and day, hence why I redlined well before I was expecting to (after having driven the car in the same configuration for 2 years, I had a good feel for when I had to change, and I usually change about 2k BEFORE redline. That's gotta say something! And because of my sound deadening, I'm sure it's not having as big effect as it does on a car that's been lightened in other ways!
I would agree with others though, it's not worth doing unless the clutch is being opened up anyway, otherwise there are definitely cheaper ways to (initially) go faster.
Well, not to be rude, but I am sure you couldn't. Plainly or otherwise. The difference in hp or weight you need to be able to detect a change is quite marked & most people only think they can feel something simply because they already know it is there. In any case you get used to changes that quickly it is not funny.
The difference in rotational mass compared to static mass is substantial. Taking 2 kg off the flywheel makes far more of a difference than taking 2 kg of the car body for acceleration purposes.
Be prepared for decreaced fuel economy, not that this really maters on a performance car.
This goes for drive shafts and tyre/rims. You will definitley feel the difference with heavier rims..!!
I'd change to lighter flywheel if I had my g/box out.
Cheers,
Edited by PX29
Cheers,
Well I can't be arsed doing the calculation, but please feel free to do it for the rest of us. In a linear state kinetic energy is equal to half the mass times the square of the velocity.
In a rotational circumstance the equation is similar, but obviously uses the polar moment of inertia instead of the mass & the velocity is measured in radians per second rather than meters per second.
Whilst removing the weight from the flywheel is more effective than just removing sound deadener or whatever it is still not significant. You will find it is << 1% of the total energy which is basically undetectable unless you are either psychic or have a shed load of data logging & alot of time on your hands.
Edited by djr81
I have to change my clutch so the boc is coming out that's why I thought i'd ask on ppls views on whether or not it is worth it....... To me seems as though if the box is coming out it is worth my while and money!!!
Mate, comparing the effectiveness of a lightened flywheel is far more complicated than the equations you have pointed out. There are many factors such as gear/diff ratio which amplify the load reduction on the engine during acceleration. Highest improvements in acceleration is in the lower gears and less effective within the higher ones. Depending on the engine, g/box, diff etc, you can reduce the effective weight of your car significantly (in first-second gear). Without going into the details which requires some serious calcs, let me assure you that you will definitely notice the difference of a lightweight flywheel. :P
Mind you it does have draw-backs.
Cheers,
Edited by PX29
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
