Hey guys,
Since i picked up my Skyline a week ago I have noticed a strange noise through a certain rev range. About 1800 - 2500 rpm. It generally happens only in 2nd and 4th gears.
The noise sounds a bit like a bearing noise, i first thought it might be a leak in the intake or something but it doesnt manifest itself in 3rd gear at all. It sounds like a hissing unlubed bearing type noise. Hardish to describe.
Once it hits boost the noise kind of vanishes with speed increase.
I was searching for something on the forums and the thread at this link might relate.
Would bearings in different gears make different noises? Should i take it back to the dealer and get them to replace the bearings?
Car is a 1993 5 speed manual Skyline R33 GTS25t.
Thanks!
https://www.sau.com.au/forums/topic/18090-noise-from-the-gearbox/
  • 2 months later...
  Quote
Originally posted by Jet
sewid
i have the same problem here. i got the noise in 3rd and 4th in the rev range of 1500-2000.
have u found the solution to it yet?
Cant hear it anymore. Induction noise too loud or its gone away... I plan on putting the airbox back on soonish so i will let you know if the noise is still there.
  • 4 weeks later...
sewid try to listen to this noise when the car is stoped and the engine going .if its aslight wound type of noise then push the clutch in and after 60 or so seconds see if the noise goes if it does then its the g/box bearings for sure if it gets worse with the clutch pedal pressed in then its the thrust bearing in wich case it shouldnt do it while driving .
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
