For the R33 use the BMW Bi-xenon lenses, if you do a search on ebay for Bi-xenon projectors, you'll see what i mean :laugh:
You might need two though because i think R33s don't come with projectors standard?
I'm using two Nissan Murano Bi-xenons on my 32 at the moment, still making up adapters and waiting for the first set to arrive
But it'll be 4-low beam lights on, all circular to match the tail lights :) then 4-high beam :)
The bi-xenons basically use one bulb for both high/low and have motors to adjust the lense and an autolevelling motor to adjust the height
Check out www.hidplanet.com/forums that's where Ronin_09 from the other post got most of his ideas for his retrofit and damn it looks good.
For the R33 use the BMW Bi-xenon lenses, if you do a search on ebay for Bi-xenon projectors, you'll see what i mean :thumbsup:
But it'll be 4-low beam lights on, all circular to match the tail lights :angry: then 4-high beam :P
Just curious as to how you will fit 4 projectors in the headlight assy. I have been thinking about 4 but today i got the idea for bi-xenon projectors and making the current high beam a big set of fog lights connected to my fog light button! yet 4 projectors would be nuts.
it shouldn't be too hard to fit 4 :)
I've test fitted a set of halogen in there, off a J30 infinity(which people say make good HID retros because they have a clean cutoff)
but I've decided that a proper bi-xenon would be nicer, I'm mocking it up on a broken headlight at the moment, I'll post pics in a few weeks when I've got the alignment perfect
Pity the R32s have the glass covers with pits in them, but I'll be hopefully making perspex covers for them, so there shouldn't be any hot spots or glare, just a solid clear lense :D
yeah I'm having one replacing the lowbeam/parklight, one replacing the highbeam :(
And angel eyes for park lights to replace the current ones, I'll post a pic up as soon as I've mocked it up :P
but the final edition will be under wraps till November-January, depending on when I finish the car, then I'll post all the pictures of my car up, from strip down to doing up, I just don't know what it'll look like or what colour yet, but it should look wicked
Do you have the projector headlights or the square looking one's? Wouldn't it look a bit funny if there was one set of projectors in a round opening and one set in a square reflector? This is what I was thinking of doing when I had the spare cash. I would keep the glass cover and see if I could have the lines inside it removed by a glass blower or something. Don't like the idea of having the perspex going faded and yellow like R33's.
Now I'm looking at bi-xenon in the projector and making the current high beams fog lights.
If I were to go retrofitting, I would just bi-xenon projectors to replace the standard projectors. I wouldn't put a projector in the high beam area because of the square shape you were talking about. Oh I guess if you were to modify the whole headlight so that you can't even notice that it was square originally then maybe.
Edited by adam-__-
I've got bugeye projector style
but i'm going for a custom perspex cover with custom shrouds, so they'll look very close to stock :thumbsup:
Here are some teasers:
I've just used the stock cover for now, but will be creating a custom shroud for the new lights and getting it chrome plated
These are from a broken headlight(i accidentally melted it in the oven, whoops)
The lenses/projectors in this are J30 and are only there to mock up for the moment, because my lights are still coming and I can't afford the second pair just yet, so I'll be putting one pair into one side first off
Stock headlight shroud(with extra projector shroud:
My test subject:
Test subject next to normal lense(I'll be making a mould of that lense then vacuum forming it in perspex, so it'll be clear with no lines through it
Oh and here is a video about glare :) one the right is standard halogen projector on the left hand side of the car is a HID fit into normal halogen projector
Totally blinding ;) I reckon we should create a sticky warning peopel about HID kits and stopping people from selling them to unsuspecting buyers
I got the idea today to get an old set and cut the projector and parkers out of it, flip that upside down and mould it into the middle of the headlight assy to replace the highbeam section. It would look like parker, projector, projector, parker. The parkers closest to the grill could then be connected to the fog light switch with some fogs installed. Just as long as it cuts through the fog, then all good. It's not like people drive around with them on ALL the time like commonwhore drivers! :P
I got the idea today to get an old set and cut the projector and parkers out of it, flip that upside down and mould it into the middle of the headlight assy to replace the highbeam section. It would look like parker, projector, projector, parker. The parkers closest to the grill could then be connected to the fog light switch with some fogs installed. Just as long as it cuts through the fog, then all good. It's not like people drive around with them on ALL the time like commonwhore drivers! :rolleyes:
That's a pretty good idea you have there.
Is this 1 set?? I didnt know that you could get twin projectors like this.
do these only need 1 ballast per headlight?
It could just be two separate projectors mounted onto a custom bracket, but they look pretty professionally done.
I would assume you would still need a ballast per bulb, correct me if I'm wrong. I've just never seen one ballast powering two globes before.
yeah one set :)
My new lights have arrived too to replace those, you need 2 ballast per headlight, because I'm having two high and two low beams per side
It'll look damn good though and Adam is right, the cut off is seriously so nice and sharp, totally worth it for the bling factor, plus with some custom lenses it'll look damn nice :)
it means the front and back will look very similar in terms of lights, both twins :no:
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
    • Yep, agree with all of the above added on too. I just love the age old "what boost were you running?" Question without getting any other surrounding data. IE, may have ran 20psi, and lived for 12 years, but it was an 80 year old granma driving it to Bingo once a week and never took it over 2500rpm.
