This is a question that is very vague to answer, and it also a question that doesnt really matter. According to some stuff that ive read, the power at the wheels is 80 - 85% what it is at the engine. Still this is just an estimate, and like I said, who really cares ...
Oh, in case you dont know the kw - bhp conversion .. its x 1.341 ... so if you have 245 kW at the wheels, you have about 328 rwhp. Not that that really matters either .. its just a measurement and i rekon ppl often quote it just cause its a bigger number and sounds better ... but not always.
https://www.sau.com.au/forums/topic/18093-horsepower/#findComment-377916
There is no definitive equation for determining flywheel horsepower from rear-wheel horsepower.
InExtremis you said that you believed it was 80-85%, well i heard it was between 67-75% (2/3 and 3/4), so that proves that it depends on multiple variables. All wheel drives also lose much more power through drivetrain loss. Ill outline a few variables that i know of but someone with dyno experience can elaborate:
* wheel/tyre size
* how well the car puts its power down
* weight distribution
In the latest MOTOR mag they had a Holden v Ford comparison and dynoed all 7 cars. Some interesting results:
* FPV GT = 290Kw@fly but made 225Kw@wheels
* HSV GTS = 300kw but made 222Kw@wheels
* Holden Caprice = 245Kw@fly but made only 158Kw@wheels
* Commodore SS = 235Kw@fly but made 182Kw@wheels
* Commodore SV8 = 235Kw@fly but made 178Kw@wheels
As you can see descrepancies are apparent in these examples. One phenomenon did occur to me the cars that performed best had more weight over the rear axles...
Hope this helps...
https://www.sau.com.au/forums/topic/18093-horsepower/#findComment-378476
For dyno-testing yes more more weight in the back will give better results (generally speaking) for RWD cars. Thats why sometime you see guys sitting in or on the boot of cars being dynoed!!!!
As for on the road, there is a fine line between good power down and bogging, and more finely adding extra weight to aid power down and the detriment of having a heavier car (the heavier the car the worse power to weight ratio).
Think of a leaf sprung suspension equiped ute with big horsepower. There's 3/5ths of stuff all weight in the back therefore there is going to be a difficulty in putting the power to the ground because the tyres wont be sitting as heavily on the road...
https://www.sau.com.au/forums/topic/18093-horsepower/#findComment-378713
only bad thing with this info is.... you are assuming that they are actually the quoted figure @ fly. Figures could well be totally correct, and what im saying would have no relevance.. but it may not be the case .
https://www.sau.com.au/forums/topic/18093-horsepower/#findComment-379160
Roughly the number of horsepower at the rear wheels is the same number of kW's at the flywheel.
so in butthead's case 245rwkw = 327rwhp
therefore if the car has 327rwhp, the engine produces 327kW (436hp) at the flywheel (roughly)
i dont think this would apply to all cars but seems to be pretty close on rwd skylines.
hope that helps....
https://www.sau.com.au/forums/topic/18093-horsepower/#findComment-379697
Haha no worries InExtremis - it's interesting that they did an article with dyno results of all our "favourite" australian cars.
Just out of interest the XR6T which won the comparison for best all round ability made 185Kw@wheels... not bad eh?!! They even made mention of the "R32 Skyline" in the article - saying not since then has a 6cyl decimated the opposition in such a way....
Btw RB25 i like your formula in working it out - very interesting but if you apply it a stock R32 GTSt see what happens:
Roughly 110kw@wheels=147.4hp@wheels
therefore 147kw@flywheel (158/162kw stock)
Almost but not quite....
https://www.sau.com.au/forums/topic/18093-horsepower/#findComment-379853
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
