ok just bought a r32 gtst 4 door my first turbo car, was just wondering a couple of things
1. what are the disadvantages of running higher boost without a front mount, will get one soon but don't have the coin atm
2. how much boost can the factory BOV handle ??
3. how much boost could i run with this stock set up???
any help would be appreciated
Edited by G-Money
https://www.sau.com.au/forums/topic/180951-r32-gtst-questions/
Its not a matter of how much boost the factory BOV can handle its how much the factory turbo can handle.
The turbo's are ceramic and realistically, with a front mount the most boost you would want to run constantly is 13psi. But be warned that gauges are often inaccurate whereas a dyno will give you a real boost reading.
Running 13psi daily without a front mount can be done but you are quite likely to be reducing the life of your turbo and you should be turbo timing the car. Either way change your oil every 5,000km!
edit - Some people may be happy to run higher boost than this as a replacement turbo is not awfully expensive and it does present an opportunity to upgrade it, but to each his own.
Edited by r32line
You'll get close enough to 200 on the stocky...
just need a bunch of other shit.
turbo back exhaust, pod with cold air box, fmic, new computer or piggyback fuel doovalacky, 13 pounds and a good tuner
Edited by joeyjoejoejuniorshabadoo
I love budget builds..
1.) R34 stock side mounted intercooler = $150 + $50 to mod it so that the inlet and outlet match the stock R32 one.
2.) GTR fuel pump - $150
3.) Stock RB25 turbo - $400
4.) Xforce Mild steel, turbo back exhaust - $700
5.) TurboTech manual boost controller - $40
6.) Case of beer to CEFFIE from these forums to remap your stock ECU - $50 :P
That will have you at about 190-200rwkw and will have cost you about $1500 - $2K
then you will need decent tyres and suspension setup to use the new found power.
My RB20 is making ~250rwhp @ 12psi untuned (but a bit lean due to old pump), currently has the following:
RB25 turbo - $300
3" front pipe - $30
"hiflow" 3" cat - $20
Greddy Profec B spec2 - was a b'day present but you can get them new for about $350-400 or you can fork out a little more for a blitz. I previously had a $30 turbotech boost T which worked fine.
Xforce split dump pipe (came with car)
2 3/4" cat back (came with car)
Chinaspec front mount (came with the car)
Got a Bosch 044 pump sitting here waiting to go in and have one of CEFFIE's remapped chips on the way. We'll see how that goes and might put an SAFC in to smooth things out a little more. Hoping to get close to 280rwhp with a little more boost out of this RB20 with minimal $_$ spent as I'd rather spend the big $_$ on an RB25 when the 20 finally dies :D
Keep an eye out on the forums, I picked up the "hiflow" cat, front pipe and turbo off local people from this forum :P
Get a FMIC setup, which is about $345 from JUST JAP, plus delivery.
Factory BOV is fine for what ever boost you want to run on the street. People are running up to 19psi on standard BOV.
I'd say no more than about 13 - 14psi on standard turbo.
That should be enough to have some fun, and reliably.
Dont forget to get a turbo back 3" exhaust as well, that will help with power/flow/response.
A GTR pump wouldnt be a bad investment either, I paid $60 for mine delivered, and it was in perfect working order.
Thanks,
Abu
Edited by abu
how long is a piece of string?
generally 200 ish rwkw.. but like everything it all depends on how you drive!
I had 225 rwkw and drifted my 32 at every track event and no box failures. yert some mates of mine blow 20 boxes with organic clutches and 160 rwkw....
Would SAFCII suffice as a "piggyback" I have all of the above inc. standard r33 turbo and stock ecu. Not to sure on power figure? Just wanting to see if it would be a cheaper alternative to going a PFC. Was thinking around 160rwkw
thanx guys thats really helpful
Generally there is a usefully large amount of gear that can be taken from either the RB25's or the 26's & fitted to the 20's.
Off the GT-R's fuel pumps have been mentioned (Got one for sale as it happens) but also injectors with suitable mods fit, as do the cams & if you are handy even GT-R intercoolers can be made to fit.
From the RB25's the turbo is the most usefull component, as mentioned.
Edited by djr81
25 turbo is the single best bang for buck upgrade you can do to the RB20. As for the gearbox, not sure about the auto's, I'm going to put a 25 engine in front of my 20 box and see how long it lasts. My mates 25/30 commodore was running a 20 box for about 6 months (because it had an RB20 in it before the 25/30) making 490rwhp, it eventually snapped 3rd gear in a big way.. loaded it up in 3rd from low revs and when it hit boost it went BANG! Depends on driving style I guess, I tend to abuse my cars a bit more than him :rofl:
SAFC II is a piggy back fuel computer.
If your chasing about 210rwkw, then the SAFC II will do the job. Once you need to upgrade the stock injectors to after market, the SAFC II will becoming useless as they cant support after market injectors with a higher flow rating.
Around 200 - 220rwkw the stock injectors will max out on RB20. Thats a rough figure, as results on the forums vary.
With the following mods;
RB25 turbo
Intercooler
3" turbo back exhaust
GTR/WALBRO/BOSCH 040 fuel pump
SAFC II + tune
Power = 175 - 190rwkw
On about 14psi that should get you about 180rwkw, but you wouldn't want to push that stock RB25 turbo anymore, but if you were to, no more than 15 -16psi max.
You should be able to get 160rwkw on the above mods, running stock RB20 turbo. :D
I also bought an SAFC II for my R32, and have just purchased cooler piping and a cooler. Once my compliance gets done, I will buy an after market turbo depending on funds, if not then a RB25 turbo.
Already have a GTR fuel pump in there, so will install the SAFC II my self and get it tuned by something.. hoping for anything from 180 - 200rwkw depending on my turbo choice.
Thanks,
Abu
Edited by abu
You'll probably notice your stock bov start to leak at about 14psi. Just get a second hand GTR bov and put that in. Can handle more than you would probably want, but it just doesn't have the 'psshhh' sound some people want.
There's been a few people on these forums that have got over the 200rwkw mark with the stock rb20 injectors. It just all depends on the tune/tuner.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
    • I think you might have skipped a whole vowel sounds there C.
