I am interested in a high flow of an Rb25 turbo, as long as there is not too much involved with getting the lines altered.
Is there any people in for definate yet, or is it still all in the process at the moment?
Thanks,
Abu
Ok people, ive spoken to John again and this is the go. With the JOURNAL bearing high flow for $1100, you need to provide John with your turbo and the actuator for it to be highflowed. You dont need to provide the LINES as you can use your stock lines. Now if anybody wants a ball bearing these will be $1550, but five people are needed to purcahse this. With the ball bearing, you need to provide the lines as John will modify them. Otherwise you can do it yourself. Everything else, as in bolts, washers will be provided to bolt back on to your turbo. There is not a lot of mucking around.
Heres all the information you guys need. So is anyone in?
SoFly and Munkey: $1550 for ball bearings on the condition that we get five. You need to provide your oil and water lines to be modified though.
Abu: If you get a journal bearning, all you need is the turbo (with actuator) as the lines do not need to be modified (turbo is only oil cooled anyway). If you want ball bearning, you need to supply the lines, and they will be modified as part of the cost
Cheers
Great to see you guys dealing with Precision Turbo's again! My GB sparked approx 40 high flows all with excellent results!
Good luck to all
Regards,
Sarkis
I installed one of Johns BB R33/VG30 highflows on the weekend.And honestly cant wipe the smile off my face.
The car will be tuned Monday week so ive just been driving around off boost and occasionally creeping into the 2psi range.Very torquey an boost starts at about 2000rpm.Had to go to Pirtek to get some braided line made up,but its DEFINATLEY worth the effort.
With the cams,555s and Z32 that will be installed next week with the tune i will probably hit 270rwkw at 1.2bar.
If you can stretch your budget i would seriously consider the BB option!
There was a delay at UAS so i wont get my car back till Wednesday night.
Suspense is killing me!
What i know so far is that the boost will be set on high at 16psi and low at 10psi.
Should a safe and solid tune.Im hoping for 260rwkw.
Hey guys.
I know not everyone has the priveledge of being able to get a turbo at wholesale price, but I recommend making friends with someone that works at Repco, cos I can get a Garrett GT30RS Twin BB for approx $1300 - $1400 through a friend. I dunno, it seems like a lot of money for a journal bearing turbo. Im currently running a journal bearing unit with VG30 housing and im not happy with the amount of lag, but I only payed $800.
Im not trying to be a dick, just throwing some other ideas into the mix. Even at RRP I reckon a new twin BB unit would be worth the extra few hundred.
Croydon are doing some really good prices: http://www.skylinesaustralia.com/forums/in...howtopic=169697
Scott
Edited by datto260Z
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
