  • Replies 40
54 in a 50 zone, that's harsh
i was told by a friend/copper a while ago that fixed camers only pin you if you're doing 10% or greater than the posted speed limit
used to be 10%, now it's just 3kmh, so even if you are only doing 103 in a 100 zone you're screwed.
Was it a fixed camera? shoulda been 3+ signs before it. Or was it a porta-revenue-raiser?
that depends on state. in qld we don't have that luxury.
Clearly you aren't a high range speeder and clearly not endangering life, so here is a link that will help you to challenge the illegal use of radars and lasers and the inadequate laws as they stand. It will also help to drag out the cases long enough to not lose your license.
http://www.aussiespeedingfines.com/index.php
high range speeders are idiots
i thought the reason speed cameras were set up for 10% lea-way was because the ADR's state a vehicle manufacturer needs to make sure the speedo is accurate by +/- 10%. they can't book you if the law states your speedo is allowed to show 60 when in actual fact your doing 66. the ADR's set you up to get fined. theoretically i should be able to drive 121kph in a 110 zone because my speedo is allowed to be out 10%. i could be wrong though.
Hey guys,
I got a speeding fine yesterday in the mail on a camera which i think i know it's location.
Bugger, only low as in 70 in a 60kms, 3 points $79..blah blah blah
Today i got 2 more on the same camera !
Different day than the first but both on the same day, one to work, and one on the way back.
70 and 72 in a 60kms zone,
Question is, is that allowed (probably)
If i'd got pulled over and booked the 1st time, you think you'd learn a lesson, but not 3 hits 3 weeks after :wave:
Had a look around but can't fine any similar occurances.
Maybe tomorrow I've lost my liscence with another 2 fines when i check the mail ??? :P :P
Thanks..
Birnie
pay for 3 and the 4th one is free lol , sorry to hear dude. My boss got caught 3 times by the same camera doing over 30km. lost his liscense for a looooong time
it used to be 10%, but now it is only 3kmh. they get more money this way.
but it is a good idea to get your speedo error checked if you are on a dyno. that way you atleast know how far it is out and can take that into consideration. some places will also adjust it for you.
Or get larger rims :-) That way it just looks like your doing a faster speed when infact your slower than the speedlimit ;-)
actually larger rims make it seem like you are going the limit (on your speedo) when in fact you are over it....
as for the original poster I agree that speeding cameras do not do what they claim (which is deter people from speeding). I mean you didn't even know it was there. you could have been doing 240kph and the camera would do nothing more than send you a bill. hardly good safety if 2 mins after passing the camera you plough into a school bus.... speed cameras do nothing more than tax us hard.
AFAIK in NSW, there is NO legislation, stating the 3 signs have to be there.
It's a "gentlemans" thing and just there to "deter" you from speeding and advise you of the limit.
I'll jump on the legislation site and try dig up the laws around speed cameras.
Hope for your sakes there's NO sign posts for speed limit as, the legislation, hasn't changed.
Part 3 of the Australian Road Rules as foundo n www.legislation.nsw.gov.au
25 Speed-limit elsewhere
(1) If a speed-limit sign does not apply to a length of road and the length of road is not in a speed-limited area, school zone or shared zone, the speed-limit applying to a driver for the length of road is the default speed-limit.
Note. Length of road is defined in the dictionary, school zone is defined in rule 23, shared zone is defined in rule 24, and speed-limited area is defined in rule 22.
(2) The default speed-limit applying to a driver for a length of road in a built-up area is 60 kilometres per hour.
Note. Built-up area is defined in the dictionary.
(3) The default speed-limit applying to a driver for any other length of road is:
(a) for a driver driving a bus with a GVM over 5 tonnes, or another vehicle with a GVM over 12 tonnes—100 kilometres per hour, or
(b) for any other driver—100 kilometres per hour or as otherwise provided under another law of this jurisdiction.
Note 1. Bus and GVM are defined in the dictionary, and vehicle is defined in rule 15.
Note 2. Five tonnes is specified for the definition of heavy omnibus in the Australian Design Rules issued under the Motor Vehicle Standards Act 1989 (Cth).
Note 3. If the vehicle is an oversize or overmass vehicle, the vehicle may be restricted to a lower speed-limit under another law of this jurisdiction.
not sure about other states but i know that in places in qld the default speed limit is set to 50kmh unless signed otherwise. for example, here in gympie main roads are signed 60, the rest are default at 50kmh even though they are not signed at 50kmh. the only time it has to be signed as 50 is if a 60kmh road becomes a 50kmh road
Hey,
ADR 18 says +- 10% (interestingly, for speeds above 40km/h :( - so yes, in theory your speedo could still be ADR-compliant and reading
50 (55.55km/h real speed)
60 (66.66km/h real speed)
110 (122.22km/h real speed)
You probably wouldn't even need to prove that your speedo _was_ -10% at the time
of the alleged offence - how would either party know otherwise? You probably _would_,
however, need to prove that you were aware of your speed at the time.
With respect to the 'aussiespeedingfines' site; surely, the best way to achieve the stated
goals (cutting govt. revenue from speeding/parking fines) is to simply offer the e-book and the
letter templates for free download. The fact that they must be bought suggests goals
other than those stated...
Regards,
Saliya
Not having a go at you or anything but 10km/h over the speed limit is a fair bit and to do it three times consecutively you must do a fair bit of speeding, so what goes around comes around I guess. It's one of my pet hates when I'm going the speed limit or just over and someone comes flying past me, especially 4WD's :rofl: it's not like that extra speed is going get you anywhere faster.
If your worried about points and loosing your license you could always pass off some of the points to someone else. You won't have much of an argument in saying 'if you knew you had the previous fines you wouldn't have speed' because that just proves you had intent to speed.
you sped you got caught too bad so sad pay attention to the what your doing next time .
if you were so distracted thinking of other things and try and use that as an excuse you shouldn't have a license
how do you get 55.55 as being 10% more than 50? 10% of 50 is 5, not 5.55, that is 11.1% of 50.
Hey,
it's to do with the expression - in english, not ADR-speak:
"The speedo must read within +-10% of the actual vehicle speed"
not
"the vehicle is allowed to be travelling 10% faster or slower than the indicated speed"
- they're two different things. For our example where we're interested in the bottom limit only
Indicated Speed (can be) = Actual Speed - 10% of Actual Speed
= Actual Speed * (100 - 10) %
= Actual Speed * 90%
But we don't know Actual Speed, we only know Indicated Speed.
So to calculate Actual speed from Indicated speed, we get
Actual Speed = Indicated Speed / 90%
= 50km/h / .9
= 55.55km/h (well, 55.5 recurring, but anyway).
The difference is bugger-all @ 50km/h (0.5km/h), but is more than 1km/h @ indicated 110km/h (122.2km/h instead of 121).
And if they're going to go you for that 1km/h, it might be important...
Regards,
Saliya
Guest B34ST GTR
I disagree with 10kph over the limit being quite alot, i find a half second lapse in concentration can increase your speed limit by 10kph easily, it doesnt even feel like any more pressure on the accelerator is required to gain an extra 10, at 60kph
I know speeding is bad and none of us should do it........
but, THIS IS A SKYLINE website not a camry cruising club, and we all share a common interest in finely built SPORTS cars, which arent exactly good on fuel or good family cars or feature loaded cruisers but they SPEED good, and thats about all they are good for.
...and there sexy.
dont think double jeopardy is going to save you here!
The concept of "double jeopardy" says you can't be convicted of the same offense more than once. In this instance, there are three separate incidents so it wouldn't apply.
I've been thinking about the idea of double jeopardy. Lets say you drive through a section of road with multiple cameras but no change in speed limit (like, say, a tunnel). If you get pinged speeding by more than one camera, I'd assert that you could only be fined once. If you don't slow down, you've only committed that offence once. The cameras are just witnesses, after all, and multiple witnesses doesn't make for multiple offences.
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
