ATMO when you don't need it, is for wankers.
You want to keep creating a bad image for all other skyline owners, go ahead. I'll sell mine and buy something thats image hasn't been f**ked in the ass by a whole heap of try hards.
I have a 300rwkw Skyline and I'm still running the factory BOV. Why? Because the car doesn't stall, the cops don't hear it, and so I don't look like a wanker.
Seriously, when was the last time chicks came running out flashing their tits and vaginas trying to get into your car because they heard the sound of your BOV? 98% of people that hear it think you're a try hard wanker. That is the complete truth.
No one cares that your car goes whoosh and backfires everytime you change gears.
sounds like u care,and crome rims so YANKIE!im a black gangster(joke)
I would say young hoons doing burnouts for thier mates or dragging every vn commodore like a twit would make skylines look bad not a blowoff valve.
its usually the nut behind the wheel that gives the image the wank factor!do you see a rally car as a wank noise?
i agree it gets anoying at times thats why i brought a valve that does both, but to say that is a bit much?but each to his own
  • Replies 100
Posted Images
Ive got my standard plumbback on at the moment (I did the whole atmo Bov thing ,it was for me)
but now ive got a new intake pipe getting made up for my new turbo and I wont be putting a return line in
so ill put my atmo back on (its a stealth fx,no i didnt waste 700 on it) but if I can get a return line plumbed in somewhere I will later on and plumb it back in
I do hear your point :P and agree in part
but why do drifters use it?isnt it ment to spool up faster on shifts for D1??
and why do rally cars use it?
I gues the motor is healthier with it plumbed back but is it more performance without?(on quickshifts)
and running no BOV at all is there alot of turbo LAG when changing gears?
rally and race cars run them because most good ones can vent much more air than a plumback, but for street use where a split second here and there doesn't make a difference, and where you aren't running huge amounts of boost it doesn't really matter.
if you are worried about lag on gear changes just don't lift of the throttle.
depends on how quickly you change gears. if you shift like a granny there will be as the turbo will have slowed down a fair bit.
on skylines there isn't much point changing as the stock one is pretty good. the stock one on s13 silvias and 180's on the other hand is crap. it doesn't work well at all and an atmo bov will make it a lot less laggy on gear changes. i noticed a huge difference when i put one on my old 180. but then i have also driven a 180 with a cheap shit bov and it was no better than stock.
:wave:
I'm with the Mafia
I know a heap of people in the import car scene, and 90% of them HATE the sound of an atmo BOV.
They love a well built car, but to them, and most people on here, the atmo BOV just screams LOOK AT ME, I'M GAY!!!
Also, every single friend of mine that is NOT into cars, can not stand the sound of the atmo BOV, they're used to exhaust noises in the local area whilst they're trying to sleep and all, but there biggest piss off is ass hats with Atmo BOV being noisy f**king idiots and going "Psht" on every gear change.
Oh, and slowest setup for spooling back up on gear changes, is actually no BOV. Why? You keep a high pressure in the intake pipes, the actuator beleives it's still making good boost, holds the waste gate open, what happens though, a whole heap less air is coming out of the motor, and the tiny bit that gets sent into the turbo is NOT enough to keep it spooled, and it slows.
Then, you can look at the plumb back setup, on an AFM tune. It spools up second slowest. Although the waste gate closes, it still spools up slowest, why? Read on to the fastest and find out.
The atmo venting on an AFM tuned car. This will spool the quickest, only by a fraction of a second. Why? Well the waste gate has closed, the AFM has seen a whole heap air still entering the motor, it dumps in a shit load of fuel, which hey, ignites in the exhaust, which spools the turbo up.
The quickest spooling way, is THE quickest way to kill your cat, and also to kill ceramic turbos.
A plumb back and atmo BOV on a MAP tuned car will not, and should not have a difference in spool times, as the amount of air entering the motor is measured at the motor, not at the intake pipe.
about time someone mentioned AFM's and map sensors.
Everyone thinks they sound like crap, so why put on on? They drive me crazy.
Nothing beats a nice turbo spool note, and no whoosh afterwards.
i run a pumback and i have never had any stall issues or any issues for 3 years... also, mine is plumback and i think it makes enough noise at low revs... how loud do people want there sound... i think the nice little bov sound sounds great, the quick little sound while you change.. never had atmo and i think i never will... no reason, dont need to do it :wave:
i run a pumback and i have never had any stall issues or any issues for 3 years... also, mine is plumback and i think it makes enough noise at low revs... how loud do people want there sound... i think the nice little bov sound sounds great, the quick little sound while you change.. never had atmo and i think i never will... no reason, dont need to do it :/
Can you send me some better pics of your car? I love black rims on silver.
Dose sounds better than a poofy BOV.
Thanks,
Abu
Dose rocks...
It's even better when you get pulled over and they go to do you for an atmo BOV when you have no BOV on the car... :/
Dose rocks...
It's even better when you get pulled over and they go to do you for an atmo BOV when you have no BOV on the car... :cheers:
Or if your smart you just block the BOV off as well as the VAC line so you dont have to take it off :/
And how do you get done for an ATMO BOV when you dont have one? lol
Thanks,
Abu
Edited by abu
Thanks,
Abu
Alot of police = dumb with regards to certain mods.
They hear the dose, beleive it as atmo BOV.
Pop hood. Scratch head. "Where is your BOV son?"
Exactly.
Police are dumb as hell when it comes to imports. You very rarely find one that knows what they are talking about.
No BOV sighted = No defect.
Thanks,
Abu
Edited by abu
someone please point out which "RALLY" car uses a bov.
all the austalian rally cars use them.... well the ones without anti-lag. i went to a round of rally australia and was standing on a corner and most of the lancers and wrxs had bovs. the focus didn't but that's cause it's natro, lol.
atmo bov are just as good as stock ones or plumb backs. just as its the same as cars with no BOV.
stop dissn others personal tastes. if u wanna get that picky i can start shootn off about other shit.
why do u tint ur windows.
why did u change ur rims
why do ppl change their airbox to a pod.
we do these things cuz we like em.....simple as that
    • Not sure what you mean by electronic speedo drive.  Speedo reads fine up to 180 yes.
    • For anyone interested, this is my old graph from 2021, but I've plotted the previous setup curve onto it with a black pen. old setup was: pon cams, oem itbs and plenum, HPI manifold, hks 2835 pro S .87ar rear, Turbosmart actuator, 3" turbo back no res. or cat., greddy spec M fmic, nismo 740cc inj, walbro in tank 460, splitfires, 4" intake pipe, Apexi pod, e85, eboost2, power Fc. I love that the new setup has much larger turbo spec with the HTA3076 1.01ar Ts rear, and literally everything is bigger, but far higher quality and result is it's FAR more responsive in paper.
    • This makes a lot of sense! I just had that realisation a few minutes ago and wrote it above haha. This is a good new discovery. "Sanding the side of the hill" perfect way to put it.   馃槀 馃槀
    • This is probably what's happened to me. I'll put filler again on my repairs and use the long block and let you know how I go. Fingers crossed it's my last batch of filler lol. I can see that happening where my block dipped at certain points because it didn't cover all the high spots at the same time if that makes sense. I'm just trying to visualise the fact that with the large sanding block I will be sanding far away from the central dent area and whether that will cause issues or whether that's going to fether out my repairs better.
